#286027 07/15/02 11:10 PM
SaV-iT Offline OP
Luke,
Could you clarify the stock sizes for both the E0 and E1 rims? Will E0 tires work with E1 rims? With standard suspension, and passengers, do I want anything bigger than stock? Thanks
#286028 07/15/02 11:43 PM
tire rack shows the tire size the same for all svt tours..which is 205/55/16..i have them on my e0 rims...and that's what comes stock on svt's w/ e1's..so to answer ur ? yes they will work w/both e0 and e1.. smile
98 silver frost svt
no cats/magnaflows
kkm true-rev
white hvac
ford blue calipers
more to come!!
#286029 07/16/02 01:55 AM
E0-98/98.5 came with 205/55/16
E1-99/00 came with 215/50/16
98.5 SVT#6092 of 6535 B/MNB
Born on date 5/22/98
Y2K Suzuki GSXR 750 Y/B with 140.6HP
#286030 07/16/02 02:26 AM
SaV-iT Offline OP
Ah-ha, conflicting reports already! From everything I've seen, E1 denotes 98.5 and up!? Were the Cobra type rims on the 98.5 equipped with the early tires, and then changed in 99?
#286031 07/16/02 02:27 AM
SaV-iT Offline OP
#286032 07/16/02 02:41 AM
The tire sizes are correct.
However:
E0 = 98
E1 = 98.5
Only the E0 had the "soft" (Heavy) rims with the 205/55/16's
2000 SVT #674 - Check it out!
Moderated by  1314_dup1
