Page 1 of 3 1 2 3
Pete D Offline OP
The sidewalls say 44psi max. I obviously cant find it on my door jam sticker so I figured I would ask you guys.
Thnx
Pete
Every time I come online I wonder if the forums will be up
My sticker says 32 psi all around and that's exactly what I run. Any more or less and I get wrong tire wear.
32 front and 34 back!
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
Why higher in the back? You like the back end loose?
I run 36f, 34b.
99 SVT Contour Silver Frost, #365/2760
91 Isuzu Impulse XS Kammback, Handling By Lotus
Victoria, BC, Canada
nope, I have a my subs and amp back there and I get the best ride that way.
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
My Ride
Pete D Offline OP
what do the sidewalls say?
I was running mine at 42 psi all around eek
umm.... im running 40 all around..
metallic teal 95 mystique V6 ATX
debadged-no door dings-K&N filter-no hoodliner-SVT exhaust (thanks steve!)- Powdercoated Black E1s -SE side skirts in the garage! LED stereo and door handle lights
It's all a matter of preference really, and practicality...if you drive a lot of city miles go 32 all around highway 35 all around if you carry a little extra weight in the back like me(stereo,luggage, dead bodies, etc) then bump the rear to 36-38 PSI
Originally posted by 99SESPORT:
First off, if somebody is grabbing your nuts, your gonna do everything you can to get him off...
And sitting there telling him politely
"Please let go of my nuts, sir?"
use the range that is on the tire. i think the kdw's on my svt say 34-44 psi so i run like 38-40
what ever the door jamb says i would disregard. Unless you want a blow out cause ford probly says to run at 5 psi.
Good rule of thumb: go by what the tire manufacturer recamends not by what the sticker says on your door.
"It's the little things that count" The Wedding Singer
svt24v@yahoo.com
ICQ: 3699352 (Contour.org for auth)
00 SVT #555 of 2150
Built 11/24/99
Bought 12/23/99
T-Red/Tan
KKM
No Resonator
Amber Cougar Side Markers
Cougar/Focus Antenna
Heated Drivers Seat
Heated Mirrors
I go by what is recommended on the sidewalls of the KDW's. 40psi for predominately city driving and 42psi for highway. If you run these 50 series tires underinflated you run the risk of bending a rim (I speak from experience from this past winter - I used to run 32-34psi). I was also told by my Ford dealer service manager that underinflating the KDW's causes cupping of the tread. Although my tires are already trashed (except for the one replaced by my insurance company) and due for replacement, I run the higher pressure for the health of my rims.
2000 T-Red SVT, #562/2150
K&N w/heatshield
Page 1 of 3 1 2 3
Moderated by  1314_dup1
