#285791 06/26/02 06:01 PM
I'm looking into buying Focus SVT rims (17 X 7) for my car from BAT. I noticed that they weigh about 21 pounds. Does anyone know what the stock 15" rims on my car would weigh? I like these rims but I do want to have a little less rolling weight. Cuz my car needs all the help it can get for power so I dont want to add much if any weight to it.
Thanks
Black '98 Mystique V6 atx. superchip,2 1/4" SVT style dual exhaust (custom) with no cat, high flow res, flo-pro mufflers with Ractive tips, 8.5" K&N conical with CTA adapter, UR Ultra Street Pulley, TH-fix. 215/45/17 Bridgestone RE730's on Konig Absolute wheels. Trans go Shift Kit, High stall torgue convertor, 24000 BTU transmission cooler.
#285792 06/26/02 06:18 PM
Y
Y
why dont you take one off and weigh it.
THIS CAR IS F***ING COOL!
bone stock for now...
#285793 06/26/02 06:24 PM
I believe 21 lbs is lighter than stock 15s. Even if it isn't You got 17s now.
"Wow, that sank fast." "Yeah, like a rock."
96 Contour GL ATX
9mm Ford Racing Wires; 2 Resonators down, 1 to go;"Special airbox"; many mods planned
Sony CD player: 50wattsx4;remote;
Speakers=50 watt Pioneer 6x8s
Ross Evans smile
#285794 06/27/02 05:27 PM
F
F
Stock 15" Wheel 16-17 lbs..... A 17" tire will be lighter then the stock 15" tire. Should put you to about the same weight. Why buy the heavy Focus SVT wheels when you can buy other nice wheels that are lighter? I have ADR Mase 17" that weigh 17.5 lbs a piece. Got them from Whalen Tire if your interested.
Chad Williams
chad5160@excite.com
'99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
#285795 06/29/02 01:38 AM
Please don't flame me for speakin out what I believe, but I have heard that a smaller wheel of the same weight as a larger-diameter wheel will spin up faster. Intuitively, this makes since since there is less mass to accelerate.
The problem with this is that a smaller wheel means a larger tire. You could end up with more or less mass to accelerate, or you might end up with the same or less.
I know from experience that a smaller diameter wheel will accelerate quicker because the mass is physically closer to the axis upon which it is being spun (the axle - where the centercap is).
The FocusSVT wheels are nice and clean and I would get them if the wheel/tie combo was under $1000 (and I didn't already have aftermarket rims/tires).
Honestly, I don't think you will notice much difference (you might hear some difference in roadnoise or feel some vibrational difference on the steering wheel). Tires will make more difference than the wheels will.
BTW - it would help if you spec-ed your car so we could tell which 15" wheels you have =)
Have you put in your $0.02 to save contour.org?? Put in what you can spare to keep the site up. Check the General Forum.
David
* 2k Black SVT on 17" Konig/Yokohama
* MB Quart all around; Alpine 7995, DEI/Alpine amps; Dynomat
Soon to come:
19" HRE 445s under GC/Koni Setup, Custom passive-AWD kit, 2 small Sequential Turbos running low boost, Sequential 6-speed, Widebody Kit, custom black-red chameleon paint; on and on...
Moderated by  1314_dup1
