#285357 05/30/02 01:10 PM
If there's a rim that doesn't fit the car, I've heard people say they get them "stamped" (or some similar term) that essentially punches holes in the correct spot on the rim. How good an idea is this? I ask specifically because the damned SSR Competitions don't come in Contour bolt pattern, and those would make nice 17's.
Chris
T.Red 1999 Contour SVT
God-Awful exhaust tips frown
Dunlop SP5000 (225/50-16)
email: the.jack@verizon.net
#285358 05/30/02 07:55 PM
That hole puncher you're reffering to would probably just be a drill press..
I guess it's not the end of the world if you have a wheel in 4x100 pattern and you get the 4x108 pattern drilled in, alternating with the other holes. If the wheel is a 5 bolt design though I doubt it would work.. could be a little dangerous..
#285359 05/30/02 09:53 PM
Any ideas on what shops might have this drill press? SSR Comps come in 4X100 for the civic's so I'd imagine that would be a place to at least start looking (not sure of the offset yet.
Chris
#285360 06/01/02 04:57 AM
H
H
do they have an open bolt pattern or center cap. might not look good w/ open drilled holes. center capped wheel would at least cover up the drilled out holes.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#285361 06/01/02 06:03 AM
E
E
My Racing Hart's are custom drilled. You'll probably pay about $25 extra per wheel, but if you get the wheel you want, its all good IMO!
The place I bought them from, called the manufacturer and they drilled them then shipped them. Chnaces are, most places will not have a drill press to do it in house.
I wouldn't do it if they were an open lug design, mine have a center cap so you see nothing. smile
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
Moderated by  1314_dup1
