Posts: 101 |
if i had a bat european handling kit whicxh is 2 inch drop at max would i be able to use 18 inch rims and if so what size tire would i need. P.S. are 17's better than 18's?
1996 Champagne GL 4-banger (ATX) (I miss you baby) AIM:DJT81185 Replaced with 1998 Neon Coupe DOHC 5-Speed R/T 1.084 60' 2.549 330' 7.112 1/8 10.872 MPH 65.15 1000' 14.111 1/4 16.825 MPH 83.12
Posts: 1,444 |
i think the offset of the wheels will be the biggest factor in rubbing. probably shouldn't go wider than 215 for the tires either. whats the offset of the wheels? do u have some in mind?
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 20 |
Go with the 17's. You obviously have performance in mind, seeing that you are going with a better handling kit. 18's will slow you down tremendously. 17's will weigh less, and will be cheaper for the wheels and tires. Not to mention a softer ride.
95 MTX SHO w/64k A'Pex SAFC, Custom exhaust 2.5" with single exhaust conversion, Sho Shop Y-pipe, Sho Shop cold air intake, 73mm Vortech MAF, race plugs and wires, many guages, Volvo T5R 17"x7" wheels, 10" sub in custom bandpass box, 300 watt Audiobahn amp, front and rear stut tower braces, subframe connectors and Eibach/Tokico setup in the garage, drivers side 4 point harness, some interior painted to match outside, Ventshade hood deflector painted to match car. http://www.picturetrail.com/gallery/view?p=999&gid=770595&uid=534327
