Ok I have a 3 in drop..now i need to know which wheel should i use..that will have the frame in line with the tire or a little above the tire..as so if not to rub without me having to take any covers off
ZTEC..Custom Abs Intake. 2 1/4 Catback Exaust (No Res)..Accel Coil, Accel Wires,Magnaflow muffler,Clear Corners,Removed Ding Guards..Fuel Cutoff Disable Switch,blue)...Headers,Turbo,Neon Underbody lights comming soon
H
H
wow 17x7 and 18x7 are tied. i think you should read it as get a 7inch wide tire.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
18's would look great but you'll have to run a very narrow sidewall(read 35-40 series)to keep from rubbing. Which, of course, will make the ride a little *rough*. Then again, if you're running a 3" drop( eek ) you're probably not too concerned with the ride quality. wink
I voted for 17x7...its the best choice for *all around* performance.
Moderated by  1314_dup1
