#284845 05/08/02 01:27 PM
I own a 98 contour SVT with stock suspension, and am planning to buy 18 inch RS-5 wheels. I have done a search on what tire will fit without rubbung, but everybody is saying different things. Can someone please tell me what tire will not rub. Im thinking 215/40/18.
Thank You
#284846 05/08/02 01:36 PM
it's mostly dependent on the offset and width of the wheel. but I can tell you this, I run an 18x8, 40mm offset, 225-40's, they rub. a coworker of mine has the exact same wheel (not same dimension, but the exact same wheel), running a 215-40, and he tells me (i have not checked into this, ie: gone for a ride in his car), he doesn't rub. we both have SVT contours, both with H&R springs, both with TD DTM's.
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
#284847 05/09/02 02:09 AM
Dirtybird I just sent you a PM (Private Message) about the rs5's.
98.5 SVT#6092 of 6535 B/MNB
Born on date 5/22/98
Y2K Suzuki GSXR 750 Y/B with 140.6HP
#284848 05/09/02 03:14 AM
read my sig they rub only on the passenger side so i bent up the fender lip and no more rubbing, even with four people and a huge system, my offset is 43mm also
#284849 08/02/02 09:00 PM
They wont rub, i just got the same setup yesterday, and after this period of time they rubbed once over a large bump, dont worry.
98.5 svt
18 rs-5, yoko parada, B&M short shift, 2 10in jl audio subs, Poineer??,ppi, poor man's kkm, no res, painted gilles and oval,NO TINT!?
Moderated by  1314_dup1
