Page 2 of 3 1 2 3
#284666 05/01/02 03:56 AM
What is the proper Torque specs? Im getting new wheels this week and would like to know what they should be torqued to so I can recheck them. Thanks
00 Black SVT #1545
Ground Control. Koni. 18" Konig Tantrum. More.
#284667 05/01/02 02:32 PM
torque till you can't torque no moe :p
95'contour se
painted interior/calipers
220wt.3-way door speakers
hyfonics 100x2 amp w/audiobahn 12'subs
no performance mods
#284668 05/02/02 12:59 AM
Latest torque spec seems to be around 80-85 ft-lbs. I use 80 now. Haynes manual says 62, but that's either for the steelies, or it's an early spec that's been updated by a Ford service bulletin.
Just checked my new wheels tonight after about 180 miles. 3 of 4 wheels needed a slight nudge to get back up to 80 ft-lbs. The 4th was taken off since the initial install to fix a leaky tire, and then re-installed by the shop. It was tight at least to 80, but I'm not sure what the shop used.
"Function before fashion."
'96 Contour SE
#284669 05/02/02 01:23 AM
You should also always torque the lugs in the right order. If you torque one nut, next should be the one on the opposite side of the hub, same goes for the other two. Otherwise uneven torquing can occur and help the lug nuts come off.
95 T-Red SE MTX
Eibach springs, Custom cat-back exhaust, Cross-drilled front rotors, Momo air race leather shift-knob, Kenwood head unit, Kenwood 600w amp, 2 12" Infinty's, 18" Tantrums w/ Yoko Paradas, SCA CAI
#284670 05/04/02 03:28 PM
I don't have an owner's manual handy, but I think the torque spec on alloys is around 30 ft-lbs. (85 lbs sounds kinda high)- I personally haven't had any problem with loosening after using the stock Ford lug wrench and the "elbow torque wrench method"
I think there's a couple of reasons not to over-torque: 1) fatigue on the wheel studs 2) possibility of tweaking wheel/ hub
Beware of tire shop air impacts!
#284671 05/04/02 06:34 PM
H
H
how much is a good torque wrench
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#284672 05/04/02 07:37 PM
IIRC the luck nuts are supposed to be torque to 60 ft-lbs, that is what I have been doing and I looked it up before. The number came from the Ford service manual for the 95 year, pretty sure on that, can't get to in at the monent
Son - 1995 Mystique LS Zetec 5-spd --> newest "mod" -> a girlfriend by my side
Father - 1995 Contour SE Duratec 5-spd
Mother - 1999 Contour SE Sport Duratec 5-spd
My CEG Registry
My Car
My Home Page
#284673 05/05/02 03:51 AM
E
E
A decent torque wrench can be 45-60, a really good one can be $100+ I picked up one from Tirerack for like 65 I think and it came with sockets and a breakerbar(for loosening) BTW the Cougar Alloys spec are 94 ft/lbs
99 Cougar V6 Tourmaline Green: MTX, KKM, Borla Dual...
#284674 05/05/02 12:28 PM
Be carefull about the spec your using for torqueing.
Roger B mentioned 85 ft/lbs. I have the factory Ford manual and the torque spec is 85 Nm. That's Newton/meters....not foot/pounds.
Don't confuse the two, make sure you're using the right scale !!
#284675 05/05/02 03:36 PM
Also don't confuse "stock" with "aftermarket" wheels.
Specs change for aftermarket. Yes, I know about the 62 spec. 30 is ridiculously low. As reported in this forum, IIRC, Ford published a technical update moving the spec up into the 80 ft-lb range. This is also the range recommended by Tirerack for most of the wheels they sell.
I "torqued" my stock alloys by feel for years, but when I went to aftermarket wheels, I bought a torque wrench. $15 on E-bay, and happy with it so far.
'96 Contour SE
Page 2 of 3 1 2 3
Moderated by  1314_dup1
