Page 1 of 3 1 2 3
#284656 04/29/02 11:02 PM
goldsmi Offline OP
Took off the Blizzacks (mounted on steel wheels) about two weeks ago, put the stock E0's back on.
Torqued 'em carefully.
On the way home from work today I noticed a periodic 'thump' at low speeds and a 'knock' on turns.
Found ALL 8 front wheel lug nuts loose - as in several turns each.
I guess it is true - with aluminum wheels you're supposed to check/retorque after about 100 miles.
AL
Red '98 SVT E0 3098/6535
KKM, Elizabethan EGR Plate, TH fix
OMP front brace
Hightower rear brace
DMD
B&M with reverse lockout disabled and centering spring removed
Mobil 1 oil and trans fluid
A6 Side Markers, Optima orange, Horn recontent
Painted Sail Panels
VooDoo Knob and pedals, RogerR deadpedal
Blau Houston & CD changer
Cup holders that work
Donnelly mirror
BAT Sill Plates
and a Bullitt fuel door
#284657 04/29/02 11:50 PM
yup same thing happened to me yesterday. thought that my wheel was going to fall off, now i'm all peranoid about my nuts :p
95'contour se
painted interior/calipers
220wt.3-way door speakers
hyfonics 100x2 amp w/audiobahn 12'subs
no performance mods
#284658 04/30/02 12:14 AM
According to my tire guy, alloy wheels should be checked 100 miles after they are installed. I'm sure this goes for factory alloys as well.
TB
Tony Boner
#284659 04/30/02 01:18 AM
I can't say I check the lugs 100 miles after a wheel gets pulled, but I've never had this problem (yet - knock on wood). What causes lugs on an alloy wheel to go loose after a short time? Just wondering, not that I doubt I should check them.
#284660 04/30/02 01:30 AM
My OZ's came loose, so I now believe in check them a day or two or 100 miles after installing/re-installing.
TB
Tony Boner
#284661 04/30/02 03:11 AM
E
E
Yes, I belive the correct procedure is to check at 100 miles, and if you tighten them any, to recheck again at another 100 miles.
I'll be bringing my torque wrench to SZ, checking periodically on my new wheels. laugh
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
#284662 04/30/02 07:30 PM
Can someone explain the science behind why this is? Does it have to do with contraction/expansion of the metal alloy or what?
Regards,
Craig J. Baldwin
99 SVT Contour - Silver - #49/2760
"To make a living is to get, to make a life is to give." - Winston Churchill
#284663 04/30/02 07:46 PM
9
9
Hey, all you have to do is tighten them with a torque wrench around 85 pounds. You shouldn't have any problems at all then.....
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
#284664 04/30/02 07:54 PM
Geesh. I thought this was only true for new aluminum wheels.
According to tirerack, the load-bearing metal around the lug holes may actually compress a bit, but once this is done, I didn't think it would happen again.
Lucky for me, I've never had this happen on my stock wheels, although I have noticed new wheels get a little loose the first time.
"Function before fashion."
'96 Contour SE
#284665 04/30/02 11:06 PM
O
O
i also thought/heard that it was only for first time mounting.
and only for alloys, as yes, the first time the metal can compress enough to give room for the nuts to back off.
but i make a habit of checking them after 100 miles and each time i change the oil.
good luck! and torque safe! :-)
Please: put something meaningful in your post subject! NOT "please readme!".
"your" is possessive, "you're" is the conjunction that is short for "you are", "there" is for "the dictionary is over THERE", "their" is the possessive one, and "they're" is a conjunction that is short for "they are". have a nice day :rolleyes:
Silver Frost non-E1 SVT/Contour
see my registry/profile: http://contour.org/carprofile/carprofile.cgi?a=display&uid=00004623
Page 1 of 3 1 2 3
Moderated by  1314_dup1
