#284259 04/14/02 12:18 AM
9
9
I just sent out my E1 wheels in the mail. They weighed 39 pounds each, including the wheel and the bfg tire....I thought this seemed very light...especially for a stock wheel. If the bgf tire weighs around 22-23 pounds, then they stock wheel would be at about 16-17 pounds!!!! Isn't that pretty light for a stock 16" wheel??? I thought most were around 21-23 pounds????
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
#284260 04/14/02 12:53 AM
You're right on. I got a flat recently and took the opportunity to weigh the naked (E1 five spoke) rim. All I had was my digital bathroom scale which showed the wheel to be 16 pounds.
I was also surprised the wheels were that light.
I've searched on the board/internet high and low for this info and the only thing I ever found was a post that said the wheels alone were 19-20lbs.
E0 Wheel Weight?
Not sure where that guy got his info.
cheers.
Neal
-1999 silver SVT #1405
stock, as in GStock
-1996 SE 5speed
#284261 04/15/02 12:15 AM
I weighed each of a set of E1 style wheels and they all came out to about 18.5-19 pounds on a bathroom scale. May scale may be a little off but I don't believe they only weigh 16 pounds...thats just a little too light for a factory wheel. laugh
#284262 04/15/02 04:58 AM
Yeah, I'd look for dremeled channels in back of the spokes... laugh
Marco Tatta
98.5 SE MTX, Duratec
EGR block, fog light
fix, custom shift boot, monsterflow intake, Ecotek valve
Quasi dual cardoctor exhaust.
Hacksaw short shift, Momo race "s" carbon knob, ghetto rear strut bar, 16 inch cougar wheels with 225/50/16 kumho 712s
#284263 04/15/02 10:28 PM
9
9
hmmm,,,,well thats what they were...39 pounds each...with the bfg tires. Its possible that the later E1 wheels were made a little different and were lighter????(mine is jan of 99 I believe)
99 Tropic green svt
Custom Stereo
borla cat-back
215/40/ZR17 Rubber
#284264 04/18/02 02:10 AM
99badsvt, would you mind telling me what you sold them for?
-Pete
Every time I come online I wonder if the forums will be up
#284265 04/18/02 04:39 PM
The E1 wheels weigh roughly 19 pounds a piece, I think 19.2 to be exact according to the specs. I'll try and dig them up in a bit...
Regards,
Craig J. Baldwin
99 SVT Contour - Silver - #49/2760
"To make a living is to get, to make a life is to give." - Winston Churchill
#284266 04/18/02 05:51 PM
FWIW, one of my E0 wheels, with a 205 profile OEM Goodyear tire on it weighed in at 40lbs on my bathroom scale.
An 18" Ace Spade with a 225/40 Toyo T1-S weighed in at 39lbs back-to-back on that scale.
#284267 04/19/02 05:43 PM
How much tread is on your tires? They could easily be worn down to 20 lbs, with plenty of tread left on them.
"Function before fashion."
'96 Contour SE
#284268 04/21/02 12:27 AM
9
9
True about the tread, PETE D, I sold them for $400, they were in absolutely perfect shape though(with the tires)
99 Tropic green svt
Custom Stereo
borla cat-back
215/40/ZR17 Rubber
Moderated by  1314_dup1
