Yes you read that right. Mounted balanced and installed just 4 hours after i ordered them, and out the door for $560. What a wonderful time to be alive. And to think I almost spent that much on a set of Kuhmo's. FWIW the shop also had a 215/50 Michelin Pilot MXM in stock $449 installed, but i wanted to stick with the BFG.
was a local shop. the tires were blems. There is a bit if flashing where the tread meets the sidewall that took ~10 mins to pull off. Beside that and the yellow paint on the sidewalls, the tires are perfect. balanced up fine, and seem quieter than the 27k old KDW's. PM me if still interested.
Not a bad price,but I got you beat.Same tyres with blems,$110 each mounted and balanced.$478 for all four.They also had the Michelin at $125 mounted and balanced,but this Michelin Pilot is not a very good tyre.
