#283913 03/28/02 04:14 AM
I am wanting to get some 17s. I was wondering how wide the rims should be and what size tire i should be looking for. Thanks for the help.
Tony
1999 Contour SE 2.0L VCT
Mods:
*BFGoodrich P195/65R14
*Pioneer 3100 Cd player
*Pioneer 6'x8' 3-ways
*2 12' Super Blue Subs
*Pyramid 400 Watt Amp
*Yellow Fog Lights
*Magnaflow Exhaust #14822
#283914 03/28/02 05:38 AM
IIRC, probably best to stick with the a 17x7 if you plan to lower the car.
215-45-17 is the optimal tire size - which is what I have.
Gator VR4 was running 17x7s with 205s (?) and he disliked it.
Good luck! smile
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00
92% says your group-NOT HOT
85% says your either wrong or BLIND
Blackhawk Down did NOT suck
you know who you are.....
#283915 03/28/02 12:28 PM
AMEN! I ran 205/40-17 Yokohama Paradas and absolutley hated em. I liked the tire itself, but the 40 series ride was way too harsh. Plus they do a very poor job of filling the wheel well....
1991 GVR4
Lots of mods done.
#283916 03/28/02 03:44 PM
Alright that sounds good. I just wanna make sure. Any rubbing, grinding, or whatever else could go wrong in the wheel well happen with the wider tire? Thanks for the help
Tony
Mods:
*Yellow Fog Lights
#283917 04/02/02 12:33 AM
I plan on buying new 17" wheels in April-May. I am sticking to the 17x7 with a 40 offset. Tires, I plan on having 225/45/17. After much research, I found this to be the best combo for looks/functionablilty on the tour.
1998 Silver Frost Contour SVT #1031/6535
~a few mods~
#283918 04/02/02 07:49 AM
H
H
i found a wheel i like. 17x7.5 42 offset, will this be a problem. i want to run 225/45 or if i have to 215/45. i think the lowest (safest) offset to go to is 40. am i remembering this right.
can i run this w/ stock suspension. i plan on eventually upgrading to coilovers w/ konis, but can i get the wheels first or should i wait.
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
#283919 04/03/02 04:10 AM
I'm running 17x7.5 with 215-45s and a 45mm offset. Plenty of clearance inside and out.
You should be able to run 225-40 with 42mm offset.
Any clearance trouble might be on the outside at the fender lips.
I believe 225-45s would be tto tall.
I recomend the 215-45-17 as a perfect fit. The 7.5 width and 42mm offset will give the 215's a much wider look.
#283920 04/03/02 09:09 AM
H
H
thanks alot SVTee.
AIM:omegazodiac
95 gl
built 4/6/99
black/tan
Moderated by  1314_dup1
