#283827 03/25/02 01:16 AM
Just thought I would tell you guys about this incredible exhaust system I found last year. I had been searching for about two years for a decent system, from the SCA, Borla and the Bassini they were all way overpriced and the sound was still not right. I was very disappointed until I heard the CarDoc Exhaust System, it was fantastic! I have had the CarDoc Exhaust System installed on my car since September 2001, and to put it lightly, it ROCKS! It is the healthiest sounding exhaust system I have ever had on any car I have owned, and I have owned some killer cars, rat motor Camaros, 440cid Plymouth Fury, small block Corvette, all the way down to a 1.6L Isuzu Stylus XS (a hot little car). All of them had custom exhausts (among other things). This of all of them, sounds the best at idle, midrange, and at full song.
The problem with the factory exhaust along with every other exhaust system that copies the factory layout (Bassini, Borla, SCA) have the same tinny, raspy, ricy ringing sound. It is because of the Y split at the back of the car right before the mufflers. It seems that the exhaust pulses of the engine hammer against the split (the exhaust is forced to make a 90 degree bend) and make the whole exhaust system ring like a bell, or resonate. No matter how trick your mufflers are, or how expensive your mandrel bends are, you cannot get rid of the sound unless you get rid of the Y split. Cardoc's system does this, and does it very well, it really is a trick system. The bends are minimal, and high flowing, the muffler is very heavy duty it is a single in, dual out.
The sound, Ahhh, the sound, imagine a burbly deep idle, a rumbly mid-range, and an almost Ferrari V12 scream at full throttle. There is no raspy, Honda fart-can sounds to be found in this system, this is a take no prisoners, go for broke, hairy-chested, rock-crushing exhaust system. If you are the type of person that likes to remain discrete and undercover this is not the system for you!
There is also some unexpected perks to this exhaust, my SVT is now quieter! Yes it sounds strange but the car is now quieter from the front! It seems that the ringing sound the stock exhaust system (or any of its many copies) makes is gone forever, the back end now has a rich deep burbly idle, a beautiful sound! I have confirmed this about a dozen times now at three different get-togethers with fellow SVT owners. It seems that ringing is a big part of the noise at the front of the car, you can now hear the DOHC sound much clearer at full song. Take a look at it, it is low-cost $350, a great deal!
-RoxRocket
1998.5 E1 Torreador Red #4507 of 6535
B&M Shifter, ShoShop UDP, KKM Intake, CarDoc Exhaust
1
1
confused
wheels and tires. i thought i was in the wheels and tires forum. :rolleyes:
99 SVT Contour
02 Protege5
X
X
what 1314 said!
Da Stealth Moblile
confused i didnt think that i had had that many drinks......
-chris-
96 gl: 18" adr reactions, SVT rear bumper & side-skirts, Magnaflow exhaust, CTA Intake, ACCEL coil, 9mm wires, Kenwood, Blaupunkt, Sony Xplod Mobile ES, OBX pedals w/dead pedal, neons, bnmotorsports gauges, autometer monster tach, and ZAINO!
Where can I get one of these systems and I really wish I could hear one of these
E
E
I guees if you like the fact that all you gained from that system is a change in sound then more power to ya.
I don't suppose you happen to maybe have some dyno plots of before and after you installed this "incredible" exhaust system do you? Seems these are elusive and hard to come by. Did you have to sign a contract saying you would not dyno your car ever again after installing this system?
Oh, and what 1314 said :rolleyes:
EDIT: And for a little more reading material, check here .
2000 SVT Contour - Silver # 1675/2150
svt1675@comcast.net
This Shine brought to you by the letter "Z" for Zaino
Mea Culpa! Sorry!
I have dynoed the system along with three others, the results are in the performance section. I was quite pleased with the CarDoc system. I haven't signed a NDA sinced I worked for LucasArts oh so many years ago!
-RoxRocket
Moderated by  1314_dup1
