Posts: 401 |
come on now, i got a 4 cyl, my car if u floor it the car skids and then grabs a few seconds later, same in corners, the car skips about  i have these FULDA "#1 german tire" 205 / 50 / r15's  help
*fixed* 1998.5 Contour SE Zetec No Cat, SVT Dual Exhaust, 2 N1 Mufflers, IAT , Diablo Chip, Iceman Intake, Polished TB, "new tranny"
Various other crap, no more mods for a while, just moved.
17.391 @ 81.03 mph
1995 Honda Civic CX Hatchback
15.34 @ 91.67mph
stuff.
Posts: 4,585 |
How many miles on the tires? What pressure are you running?
Posts: 401 |
500 or less miles, and the regular pressure.. 31.5 lbs..
17.391 @ 81.03 mph
15.34 @ 91.67mph
stuff.
Posts: 1,969 |
I thought presure was supposed to be around 35psi?
Kharma is very real and she is one mean b!tch.
Posts: 401 |
i don't know, i put the gauge and it said 31.5 except the 2 rear, one said 33 and the other was like 32.5, also when i turn the car to the left it makes a bad vibration sort of, and makes a noise sounding like its rubbing somthing, i looked around, i can't find anything...
17.391 @ 81.03 mph
15.34 @ 91.67mph
stuff.
Posts: 4,585 |
The first 500 or so miles you are wearing off the worst parts of the tire. By 1000 miles you should have a better feel for how the tire will work. For better sponse, run higher in the front. I push my cars pretty hard and usually run 36-38psi in the front tires on FWD cars. Wehn autocrossing, 45-50psi is common.
If nothing helps, I just take it as one more example of not ot buy store brand tires.
Posts: 1,071 |
I've got 225/50/16 Fulda Extremo tires on my SVT and am very happy with them. They grip like mad. The only thing I'm not to happy with is the sidewall stiffness. They tend to float around a little bit when cornering really hard. I've got about 1500 miles on them
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 57 |
Just a thought: I just got the bridgestone potenza re950 because I'd had enough of the goodyear eagles that came with the car. The difference is like night and day....feels like a different car. Steering response is better, they look good, grip is better and they are quieter. Only downfall is that they ride a little firmer....but it's worth it to me. I'm running 205 60 15 on mine.
