#282676 01/17/02 01:34 AM
F
Fries Offline OP
F
It is time for new tires on my 2000 SE Sport. It came with 205/60/15 Firestone Firehawk GTAs. I wasn't the original owner, but the car has 22k and needs new rubber. I did some looking and couldn't find any solid information on 15" tires. Right now I'm looking at the Dunlop SP Sport 5000, BFG Comp T/A, Bridgestone Potenza 950, and the Firestone Firehawk SH30. Any opinions out their on which is the best? I'm looking for a solid year round tire with good performance, and I'm trying not to spend too much.
2000 SE Sport MTX --- White
#282677 01/17/02 03:26 AM
V
V
I ended up getting the Potenza RE950, about 6 months ago. I like them, they are suppose to be really good all-season tires. Haven't tried them on snow yet but on dry and wet roads they are great, especially compared to the stock firehawks. And this much I can also tell you they are very stable up to 90mph. wink
1996 GL Red Contour, Zetec, ATX
K&N Filtercharger,aluminum mesh grill
OBX Fog Lamps, Viper alarm
FocusSport High Performance 8mm Spark Plug Wire, LEVOC custom ATX shifter
Panasonic CQ-FX620U Head Unit, Panasonic CX-DP88 8-disk changer, Infinity Kappa 572.5 Front/Rear
JCWhitney 80W Xenon Headlight low beams
CEG sticker, Bridgestone Potenza RE950
Magnaflow SS Race Series#14830 & Resonator #10424
#282678 01/17/02 12:59 PM
APT Offline
I'd go with the Dunlop or Bridgestone.
#282679 01/17/02 04:45 PM
I too have the 950's. I had a small bout with winter weather a few weeks ago (bought them over the summer) and they were very good in the slushy/snow mix. Only slipped once, but it was more ice than snow, and I knew I was going to slip. They were also very predictable in the winter weather. I highly recommend them as a good all season tire.
David Litsky
AIM: DaveL225
My Car
#282680 01/17/02 09:08 PM
What did you and the previous owner DO to that poor car? Mine has 20k on the same tires and they look almost like new.
2000 Contour SE Sport T-Red MTX, Mystique rear dome light, Blau Florida cd.
#282681 01/17/02 10:44 PM
My OE Firehawks also wore out in about 20, but partly because the front end was out of alignment, and I don't think I rotated as religiously as I do now. (Wisdom is gained from experience, not lecture.)
"Function before fashion."
'96 Contour SE
#282682 01/18/02 02:52 AM
F
Fries Offline OP
F
When I purchased the car from the dealership the front tires were severly worn down. As soon as I got the car home I rotated them, and they have been in back ever since. What I have in the front right now has what I consider normal wear. I am assuming that the previous owner never rotated the tires. Right now I am leaning towards the Potenzas, thanks for the help.
#282683 01/18/02 03:24 PM
I put Goodyear Eagle HPs (P205-60HR-15) on my 96 2.5L SE. They handle very well dry as well as in the rain and are wearing well too. I'll get another set once these are done. Should be able to find them for about $75 or less each, minus M & B.
Saw them mail order as low as $62 recently.
Dan B.
#282684 01/18/02 05:44 PM
Just got the Dunlop SP Sport A2 for the wifes Mystique. They are much quieter than the D 60s that were on before. A softer and better ride than the D 60s. She drove it in the snow the other day and she said they were good. I haven't tried them yet myself. I have the SP 5000s on my SVT. I got the car with the tires well worn and they are almost worn to the wear bars now. They don't perform well in the rain anymore but I think that is do to that the are worn out. They did last a 40000 miles.
Green 2000 SVT #1166
mods-K&N open air filter & Custom heat shield, Custom y pipe and 30 in resonator,DMD, arm rest heightened
http://www.geocities.com/savinoss/Cars.html
other cars-89 sable 197000 miles and still going-Wifes car 99 Mystique V6 5 spd
#282685 01/18/02 06:05 PM
i have the sh30's. i think they are a great tire. decent wear and the grip very good. the only thing is that they are a little loud of a tire. other then that no complaints.
Black '98 Mystique V6 atx. superchip,2 1/4" SVT style dual exhaust (custom) with no cat, high flow res, flo-pro mufflers with Ractive tips, 8.5" K&N conical with CTA adapter, UR Ultra Street Pulley, TH-fix. 215/45/17 Bridgestone RE730's on Konig Absolute wheels. Trans go Shift Kit, High stall torgue convertor, 24000 BTU transmission cooler.
Moderated by  1314_dup1
