Yes, you are right, but the big problem is not the ride but the height, I keep hitting the bottom of the car all the time. First I thought about changing the shocks but they are OK, what I want is to raise the car as much as is safely possible by using the wider and higher tires that i mentioned. Any thoughts on these size, would a 205/70 r14 be safe? Im sure it would be tall enough to solve the height problem but can I get out with it this way?
