Posts: 334 |
Mobil + Ford Friction Modifier is what I'm running its sweet smooth riding!
98 Contour V6 MTX KKM/Niehoff Wires/Bosh+4/Mobil 1 Oil/Tranny/Pioneer CD/Speakers Predator Alarm...more 2 come!
"Dana, if by accident, I dropped an 7mm rachet inside your secondaries your engine would be ok? right?" "Trust me if I could go back and change, I would be stuck in the past" MartinS
Posts: 178 |
SB Syncroshift...at $12.95 per quart, it is the most expensive, but it is the best. Period
98 Black E0 #946 of 6535 Koni struts & Eibach springs 24mm Aussiebar Pro Flow 75mm MAFS calibrated to KKM filter Wilwood Brake Kit with cross-drilled rotors Clutchmaster's Stage 1 Clutch & Fidanza Flywheel Custom Dual Exhaust with an Xpipe MSDS Headers Custom Cold Air Intake with KKM filter Dyno'd at 177 hp and 156 ft-lbs
Posts: 3,567 |
Originally posted by -HWCM-: AMSOIL!  this guy is the only one with his head on his shoulders. AMS OIL is BY FAR better than all others on the market. It is also the most expensive. Go to www.amsoil.com to get some.
"careful man, there's a beverage here." e-mail: boseraq@hotmail.com aol IM: madhat1412
Posts: 134 |
1998 SE atx Svt exhaust No rez Svt rims Cta intake B.A.T handling kit Door dings all gone Sony 850x head unit,10 disc cd changer,2 12 JL Marathon amp 600w Painted brakes red :o( dyno at 123hp/133tq(stock) Mods in the mail
Posts: 82 |
I spoke with Leo Capaldi this weekend about this. They started out with another type of atf... they were having gear problems with pitting and discoloration iirc. They tried a few combos and were basicly outa luck.. nothing was preventing gear trouble. They ended up turning to Ford... Ford has been working VERY close with Leo on the mtx75. His box is built well beyond spec... even moreso then the bulldog box. Most parts have been upgraded... we're talking diffrent metals not just simple changes. Thier final choice was ford synthetic.. .now of course this is ford talking.... Look HERE That is Leo's post in our forum. Take it for what its worth... but NOBODY abuses a mtx75 like him... remember.. he blew 18 boxes in one season......
Posts: 7,329 |
Originally posted by exigent: His box is built well beyond spec... even moreso then the bulldog box. Most parts have been upgraded... we're talking diffrent metals not just simple changes. You should look at the Bulldog box specs... Pressurized lube and coolers, different materials used, NOT stock by any means... etc, etc...
Posts: 82 |
demonsvt... i understand your skeptisism... What i got from talking to Leo is that he thought he would melt a buldog box just as quick as a norm mtx75. I wasnt able to discuss it with him enough... and since Terry doest say what exactly is done... its almost imposible to even discuss this. I cant tell you about leo's tranny... and Terry wont talk about about his...
Here is how he represented it to me. They were told by Ford that the mtx75 was not made to handle what they were doing to it. NOTHING inside.. or even the casing for that matter was able to take what they were givving it. So you see... leo MUST use a mtx75... but this one is much much much diffrent. Sure the pressure lube and heater cooler is great... but it wont prevent a gear from shredding itself... I dunno.. maybe leo and i underestimate Terry... its posible.. im trying to get them to talk to each other... and im sorry.. but back when i *****ed last time about the notion that Terry "discovered" the sho berrings i was told that Terry and Leo are old friends... well... dont tell Leo that.. its news to him. ANYWAYS... here nor there... im not trying to turn this into a my expert is better then your expert.. cus thats not it. Im just saying that until i learn more about what EXACTLY a bulldog box is for the price its not worth it to me... a pressure lube system and a heater cooler with upgrades to the syncros is all i heard for certain so far... that doesnt make the gears any tougher... i think a person would be better off getting a hardened gearset and quaife going from there... bet it would outlast a bulldog box.
Im not trying to start a problem here... its just that leo called into doubt the bulldog box which i for one have always held as awesome. When a man who has the mtx75 experience he does tells me my tranny plans are MAY be flawed... i listen.
Posts: 884 |
I won't use anything but Amsoil.
FWIW John
Posts: 3,567 |
Originally posted by SQPlus: I run Mobil 1. Its a little cheaper than AMSOIL and Redline. right but AMS OIL is the better of the thrtee by a long shot. order some here www.amsoil.com they'll ship to you door in about a week.
Posts: 17 |
SVT 98 Silver Frost 18 tsw Revo Eibach springs./ Kyb GR2 struts
