mello88 Offline OP
Hi, (yeah I searched)
The 4x108 spacing makes finding aftermarket wheels pretty hard. From what I've heard though, and 4x100mm wheel will work, provided I take it to a machine shop to have the spacing redrilled to 4x108mm. Would it be possible to find replacement rotors that were 1.) bigger diameter (278mm at least) 2.) Cross drilled/slotted, and 3.) 5 lug, or 4x100mm or 4x114.3 (or any standard) size?
If replacement rotors cannot be found, would it be possible to order a kit like the Baer kit, and have the rotors machined to have a different bolt pattern?
FWIW, I have a '99 cougar, and NECO is down ATM.
Thanks
~mello
What? Since the Focus came out there are TONS of wheels available... Call around man, they're out there...
Brad Noon
'99 SE MTX
3 point oh my God H.O. 179HP/178TQ
BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc
BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!
bnmotorsports@msn.com
mello88 Offline OP
I went to a bunch of sites, and found a couple different sets of wheels that I like. Of those, I called the manufacturers, and they do not make them in 4x108 bolt pattern, nor will they sell me a blank set. This leaves me with the option of getting them redrilled, which I'd rather not do (thinking it would look interesting, due to the lack of a 'cover' for the lug nuts), or asking about getting different rotors... Or, like you say, I could say, "Well, I really like these, but they don't fit" and go find another set that I don't like as much (but fits) smile.
Odds are really good that I'll just get a 4x100 set and redrill them, but this question was more out of curiosity than neccessity -- is it possible to change your bolt pattern?
~mello
mello88 Offline OP
I guess I will answer my own reply. I forgot that the older (pre 94) Mustangs came with the 4 lug pattern too. The newer Cobra R wheels (5 lug) wouldn't fit, so there were some conversions done. Doh.
If anyone else is interested in this topic, check out http://www.stangnet.com/tech/lug.html
~mello
To my knowledge, Ford hasn't made any front wheel drive cars with 5 bolt hubs/rotors. That leaves you to redrill your stock rotors or have the wheels redrilled. Which wheels are you wanting anyway? There are usually several "copy" brands which make almost the same wheel... Tire Rack, Discount tire, SCA, BAT... several others all carry several different styles in the correct pattern and back spacing.
Brad Noon
'99 SE MTX
...and this doesn't even cover offset. Any RWD rim won't have near the correct offset.
2000 SVT #674 - Check it out!
Any year Taurus is 5 lug
**Spelling should not count**
2000 SE Zetec ATX
Medium Steel Blue (Now with large custom dent on the rear door)
Cool Blue Lows, Silver Star Highs (great lights)
"If what I said was wrong, it wasn't. I just forgot to add the rest of my post."
Probe is a 5 lug FWD,around 114/115mm,not sure of stoc offset.
V6 MTX
'Its only nuts & bolts!'
Haines Motor Sports Inc,
Frick... POP (head coming out of arse) forgot about both of those cars...
Brad Noon
'99 SE MTX
Really though that soounds like a lot of trouble for what you can get just about any rim in any offset, bolt pattern, whatever.
Just look a little harder, there all over.
2000 SE Zetec ATX
