Posts: 1,812 |
Almost time for some new tires. So, of course, I'm exploring all options. I like the KDWs I have on my car now, but I looked into 225/45/16 tires (pretty good selection) just for fun. Anybody have this setup? Pros? Cons? Should I steer clear? Should I be a poineer?
2000 Silver SVT #1602 Check it out in the registry! Mi Coche
Posts: 1,086 |
Derk2000, You can be a pioneer if you like, but this combo is not recommended.
For one thing the 225 section width is really only feasible with a 18-inch diameter wheel. For example a Plus 2 fitment for the E1 SVT (OEM 215/50-16) would be a 225/40-18 or even a 225/35-18. Although the latter would provide a very stiff ride & possibly poor aesthetics due to the short sidewall height.
Similarly, the 45 series sidewall on a 16-inch diameter wheel is really too short & thus the ride quality would suffer. Also the appearance of this combo would look odd due to the fact that the short sidewall would not "fill" the wheel well enough, creating an unsightly gap between the top of the tire/wheel & the fender.
Either go with the OEM combo listed above or the original OEM SVT combo of 205/55-16. Or the Plus 1 option of 215/45-17.
1999 SVT Contour, #2140 of 2760, Tropic Green - Medium Prairie Tan Koni Sport struts; TSW Blade wheels; Nakamichi, a/d/s/, Boston Acoustics, Infinity I.C.E.
1989 Saleen Mustang, #89-0408, too many mods to list here
Posts: 4,899 |
This is what people have fit to SVT wheels based on what I remember:
205/55R16 215/50R16 215/55R16 225/50R16
I would not go any further than 225/50R16...IMHO that's pushing it. 205/55R16 or 215/50R16 (standard SVT tire sizes).
Posts: 4,319 |
Originally posted by TheContourGuy: IMHO that's pushing it. 205/55R16 or 215/50R16 (standard SVT tire sizes). Pushing what? I am kinda lost on that? You can go lower and wider if you want. Check out this site to see how much of a difference the sizes REALLY make...
1991 GVR4 Lots of mods done.
Posts: 1,086 |
T-RedSVT, Say, that's a pretty neat little feature. I'll have to bookmark that page for future reference. Thanks.
Posts: 4,319 |
Don't thank me..thank the forums. It is an old link but very useful...
Posts: 1,812 |
thanks for the input guys. i'm just exploring my options btw, i used to use a tire size calc from some corvette site, but I think I like this one better any other input?
Posts: 73 |
FWIW, I have the Kumho 225/50-16's on my 'tour w/ the SVT E0 rims. I've never had a problem, even with 300 pounds of Emergency Medical Services equipment in the trunk and the car loaded with passengers going over rough bumps and sharp turns. NEVER any rubbing. There just not as wide on 6.5 rims like they are on 7". I've measured the section on mine compared to the section on a 1999 Grand Am GT. Now if you mount these on 7" wide rims, they might give you a problem. I've never heard of anyone going wider than a 225 section without serious mods to the wheel wells. 215/50-16 is probably the most ideal, though. I just felt like going to the extreme for a change...nothing else better to do around here. Anyway, HTH.
-Rob
1999 SE Sport, Medium Steel Blue (CEG member since 2/98) SVT Dual Exhaust w/ Magnaflow res. and 3 1/2" SS Tips, E0 SVT Rims w/ Kumho 225/50ZR-16's, Superchip, SVT KKM, SVT Side Skirts, SVT front and rear bumpers, BNM white-faced gauges w/ blue glow, Carbon Fiber Shift Knob, no intake resonator, BAT Big Brake Kit C, Roger R dead pedal *DEFINITE future mods, by 7/02* wider rims, Y-pipe, revised exhaust, SVT TB, SVT Upper Intake w/ powder coating (GO BNM!)
Posts: 1,041 |
Depends if your lowered or your suspension. I use 215\40\17 and would not think of going to a biiger size due to rubbing. You might wear out a tire way to fast for what the price is. Choose wisely. Good Luck!
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Posts: 227 |
I'm confused here, too. What's wrong with him going to a 225/45-16? True, the speedo would be off by a couple percent. It has less chance of rubbing than the 225/50-16 size that has been used by CEGers before. Am I missing something?
ND SVT 2000 SVT (Black/Midnight Blue)
