I need new tires. Currently i have the g-Force KDW. Should I stick with these or try something else. Any insight would be much appreciated.
d ~ 98 SVT E1
#6196 of 6535
Depends on what you do and do not like about
your KDWs and what you think needs improving.
Noise? Ride? Grip? Wet traction? Wear? Turn
in? Response?
T.
Well seeing how you live in SE MI like I do I HIGHLY suggest that you invest in a set of snow tires/rims. The KDW tire isn't and M+S tire as you know. If you like BFG you could get the KDWS which IS an all season tire and has enough speed rating for our cars. I don't believe that is has the "AA" traction rating of the KDW but thats the trade off when you go to all season. If you do go with "snow tires" make sure you get a narrow tire size, like a P205-60-15. You should easily be able to buy 4 snow tires, 4 plain steel rims for $500.00 which is alot cheaper than repairing your car when you loose it in the snow eek I know its alittle far to drive but we have a club discount at the Discount Tire in New Baltimore at I-94/23 mile, heres the number 1-810-949-0280 and ask for Paul.
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
Well go to www.tirerack.com and search for any of the performance all season tires. They should give you good dry and wet performance. I hear good things about the g-Force KDWS.
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
I've had Arctic Alpines for 3 winters on my SVt (Ontario--we get mucho snow and ice most winters smile ) on seperate rims with the 4th coming up--only way to go if you want to keep driving in winter with stick and keep the performance aspect. About $800 since rims are Aus Mondeo alum rims--very close to original look on 15" tires rather than orig 16"
CaseyK
'99SVT Tropic Green #401
Moderated by  1314_dup1
