Posts: 1,210 |
Not to be prick, but some names and specs would do wonders here...
Posts: 1,108 |
Originally posted by Milan007: Not to be prick, but some names and specs would do wonders here...  Those are ADR reactions.Above
Kick Ass don't Kiss It
Posts: 1,090 |
Originally posted by Milan007: Not to be prick, but some names and specs would do wonders here...  If you're interested in 18's, I'm also running the same package as Antonio. The wheels are Team Dynamics "DTM"'s, sized in 18x8 with 40mm of offset. I've been running 225/40-18's, but you may be better off with 215/40-18's, due to the slight rubbing incurred with the wider wheel and tire. Antonio is running 225-35-18's. If you want to get away with no rub whatsoever, you'll need to look for 18x7.5's or narrower, with a 42mm offset. I've had my setup for over four years now. Also, I had to have the rear fenderlips trimmed to keep the rubbing to a minimum. Some shops can trim the fenders for a fee.
Posts: 517 |
Team dynamics doesn't make those DTM wheels anymore. You would have to find a used or left over set.
2000 SVT (silver) #1529 of 2150 ------------------- yeah...its modded
Posts: 1,210 |
Originally posted by showtime: Team dynamics doesn't make those DTM wheels anymore. You would have to find a used or left over set. It figures... Oh man, oh man. OJ had an easier way getting off than me findin' the rims...
Posts: 1,210 |
Those are the exact places that I went to! I guess they'll have to drill them for me... :rolleyes:
Posts: 1,090 |
Originally posted by showtime: Team dynamics doesn't make those DTM wheels anymore. You would have to find a used or left over set. They may have a few sets still in stock, I would call TD to find out.
Posts: 16 |
I called Discount Tire Direct and was told I needed at least a 45 mm offset with 18" wheels. Will 42 (or 40) work? Also, will 225/35-18's fit on 7.5" wheels? Or do they need 8"? I have been considering 18" Konig Tantrums with 225/35-18 Yokohama AVS's. IF I need to go to 215/35-18's I would have to go with the Parada's; AVS's are not available in that size.
Thanks, Martin
Martin
99 Silver Frost SVT
#1060 of 2760
New 2000 engine at 25K thanks to Ford 18x7.5 Alba Blaze rims 225/35x18 Bridgestone Potenza S-03 Pole Position tires EBC Sports brake rotors in front EBC GreenStuff at all 4 corners Pioneer DEH-P3000 AM/FM/CD Pioneer TS-A6813 all around JC Whitney Diamond Blue 65W low-beams Sylvania 885 50W fogs DRLs
Posts: 314 |
Check out this web site www.fastco.ca, it has the Konig Adamas Grandeur replicas under tuner wheels (Fast 17). I own the 16" version but they are now available in 18's with a +46mm offset. If you want to see a pic of these wheel's on my car just e-mail me @ andy.lebel@home.com. I've got many complements on them. Andy
Black 98' Merc Stique GS MTX Duratec
Cat-back 2.5" SS plumbing with Flowmaster 40 muffler KKM True Rev induction Eibach Lowering Springs 16" Fast 17 wheels with 225/50/16 Potenza RE910's Code alarm with pager 20% tint on sides and 5% on back Alpena Racing pedals Painted calipers (black) 55W & 65W Xenon Headlamps Mobil 1 Synthetic ATF with Ford FM Clear Side Markers w/orange bulbs Removed rear badging
"Park it, or put a porch on it!"
