#279037 05/29/01 01:41 PM
Patrick Offline OP
This weekend I worked up some courage and cut my fender lips back with a pair of tin snips (metal shears). I didn't have to trim the entire way around, just where the rear bumper seam joins the fender. It took a while but it was reasonably clean and unnoticeable from the outside. I tested it out on our horrible PA roads and the rub has been banished from my car. Tools needed: tin snips and a metal file. Nothing to it really.
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
what offset are your wheels. just wondering to hopefully save me from doing this when I get wheels. thanks
96' LX (de-badged,konis,ground controls,injen intake,hose techniques kit,gauge pod,phantom gauges) more soon...
Patrick Offline OP
My offset is 38mm, which was the reason for my problem. The very outside edge of the tire would rub. If I could do it over again, I'd buy wheels with more offset. But then again hindsight is 20/20, right?
'98 SVT
make sure you protect those fresh cut edges with some paint, I remember those PA winters, salt and crud make for a $hitty paintjob.... frown
Todd Christ SVT Contour Registry
MODS: KKM Intake, SHO Shop Y-Pipe, Bullit Fuel Door, Edelbrock RPM Resonator
'98 E0 SVT Contour #1037 of 6535
I grinded it off 2 years ago...worked great!
98EO SVT, Black #30
Born on 25 March 1997
You don't like it???...GTFO!
rainshdw
Patrick Offline OP
Good call, Toadster. I just happen to have some touch-up paint lying around that would be perfect to cover the newly exposed metal. Now I don't cringe going over the many bumps, potholes, dips, and gaps in our great PA roads. Now I worry about bending a rim... smile
'98 SVT
Moderated by  1314_dup1
