Kdw's are better then the Fz4 in grip how.
Are you talking dry roads,wet or snow.
KDW z rated tires have a 400 tread wear and the FZ4 have a 300 which means there rubber is softer and will grip the road better on dry roads. I tried driving on some light snow with my kdw and they sucked. And all the rating are the same except for the tread wear. With the goodrich all you paying for is the brand name and all the over head from the stores that carry them.
Now the GSC that use to come on the svt back in 98 had a far better grip the the KDW. The only reason they switch was because the gsc wore out too quick and the KDW has a bit better wet road traction.
With todays compounds and rubbers you could pick almost any zrated tire and have it perform as well as any other. Both the fz4 and kdw along with almost all the other name brand zrated tires ahve a AA rating in traction and a A rating in Temp. The treadwear is the only thing that is different in most of these tires. I dont run fz4 on my tour i run the t1-s and they would smoke the kdw.
Brian
Originally posted by Barry:
I have run both Toyo FZ4 and Dunlop SP5000 on my 95SE. I think the Dunlops are a step above the FZ4's. I now run KDW's on my car. KDW is far far superior to FZ4 in grip. Of course, this is not really a fair comparison.
Barry
