Posts: 14 |
Will 225/50 16 fit on our SVTs or will they rub. According to Tire Rack they have the exact same overall diameter as 205/55 16s. It's just the width is over an inch more. Thanks Jim
98SVT #245 93MR2 Turbo w/ many mods
Posts: 247 |
Haven't tried it myself, but CEGer Jim Johnson has the 225/50's on his SVT, and says they fit like a charm...snug, but no rubbing.
Craig 99SVT black/tan 2725 of 2760
Posts: 1,861 |
It's true, my BF Goodrich g-Force T/A KDWS (not KDW) in size 225/50R16 fit like a charm. Luke at tire rack is being cautious (as he should be). After I placed my order, he called to confirm that I really wanted that size. The packing slip was noted that customer has responsibility for fitment.
The KDWS is slightly wider that the Continental 4000H of the same size that I took off, and the fit is slightly closer, but there is still room.
Jim Johnson 98 SVT
Posts: 65 |
They will fit fine. I had them on my 98 svt and they were fine. Brian Originally posted by mr2guru: Will 225/50 16 fit on our SVTs or will they rub. According to Tire Rack they have the exact same overall diameter as 205/55 16s. It's just the width is over an inch more.
Thanks Jim
2000 SVT Green KKM True Rev Pioneer 6200 Head Unit Rockford 800a2/600a4 amps Infinity kappa's/Polk 12" dx128 subs Short throw shifter/Voodoo Knob ADR Revolution Rims Toyo T1S 215/45/17 Bassani Cat Back
Next Mod: SHO Y PIPE/Diablo Chip
Posts: 91 |
I've been running 225/50/16 Bridgestone Potenza's for about four month now with no problems.
Posts: 71 |
Have any of you noticed a change in the accuracy of your speedometer??
I'm up to 10,000 miles on my KDW's and need to start thinking about new ones...
Jason L Brougham jbrougham@yahoo.com 2000 SVT Tropic Green # 899/2150 Build Date 12/13/99 KKM True-Rev Bassani Quiet Thunder Cat-Back B&M Edge Shifter OBX Billet Pedals http://photos.yahoo.com/jbrougham----------------------
Posts: 91 |
By those stationary radars that they around here my speedo. is right on at 50mph
