Gerald Offline OP
Hello, just a quick question (hopefully). From what I understand, the offset for the stock 16x6.5 SVT wheels is +47mm. Is it the same for the Cougar 16" wheels? I've looked around and some people say it's +42, while others +47.
Black '98.0 GL V6/MTX, tints, SVT airbox (sans fender boot), stock muffler replaced with spiral racing muffler, A6 side markers, Cougar 16" polished wheels w/ bald 205/50/16 Yoko A520's, Mobil 1 5W30, Castrol SATF/Ford FM tranny cocktail, 9005 high-beam bulbs all around, re-aimed stock foglights
Offset is 42 for both.
"If you're pushing crazy I'm all full up here."
{Black '96 Contour SE MTX w/ over 126k on the clock}
· Get the skinny here.
· Need a 96-00 Ford Service Manual on CDROM?
JVT Offline
I must disagree.
Looking at my stock wheels, 49mm is what is
STAMPED on them.
John
'98 SVT - modded
-15.01@91.8
'95 Suzuki GS500E
-faster than the above
---wanting a Speed Triple or Superhawk badly
Oh poo I swear it was 42 John. I've been wrong before though. Only once but I was 5.
I too would like the straight poop on what the stock offset is on the SVT wheel. It is quite important when dealing with availibilty of aftermarket wheels. I assume a range is acceptable, but what range?
Thanks.
87 honda civic si
88 bmw m3
89 alfa milano 3L verde
98.5 ford contour svt
93 honda NSR 250sp
EO wheels have a 49.5 mm offset according to the Ford factory video that compares the differences between SVT Contours vs. other Duratecs. (Tape is posted in classifieds under miscellaneous.)I would expect E1 wheels to be the same, but can't point to a specific reference.
Mark
Gerald Offline OP
Thanks for the info guys. Might not have reached a consensus but I'm satisfied that they're within the "acceptable range".
Focus and contour are the same 4 lug 108 offset. Im not sure if the cougar fits in that but I would think it would.
Brian
2000 SVT Green
KKM True Rev
Pioneer 6200 Head Unit
Rockford 800a2/600a4 amps
Infinity kappa's/Polk 12" dx128 subs
Short throw shifter/Voodoo Knob
ADR Revolution Rims
Toyo T1S 215/45/17
Bassani Cat Back
Next Mod: SHO Y PIPE/Diablo Chip
I have seen on the cougar forums board where someone replaced stock 'tour wheels with the stock polished cougar wheels. Our wheels "I own a roush cougar", are 4x108 and the offset is +42mm. hope this helps
'99 Roush Stage 2 Cougar
custom grilles and stereo
and YES its a COUGAR
Moderated by  1314_dup1
