I am buying new wheels but need to submit all the OE specs to Tire Rack so they can figure what will clear the Wilwoods.
I primarily don't know the offset and bolt pattern.
If someone knows all the specs for the early cars' flat-faced, 6-spoke wheels (I don't know if that is a good description), that would be great.
1996 Contour SE, 5-speed, Black A'PEXi S-AFC, Scorpion cat-back exhaust, MSDS Headers, SHO Shop Y-pipe, Fidanza flywheel, Quaife ATB differential, itg foam filter, Magnecors, Koni's, Eibach's, Sparco front strut brace, SHO-shop rear strut tower brace, BAT 22mm rear anti-roll bar, Wilwood Dynalite 4-piston calipers, SVT size rotors, Aeroquip brake lines, 17" OZ Superleggera's, Dunlop SP Sport 9000's
