Patrick Offline OP
My offset is 38mm and I'd like to increase it to 41-42mm to cure the rubbing. The car isn't lowered. 17x7.5 Panther 199 wheels with 215/45/17. I know the dangers of increasing the offset with shims, plates, etc so I'd like to try 40mm first and then 42mm if they're not too expensive. I haven't seen anything like this for our 'tours. Who can help me out?
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
Offset is the measurement from the centerline of the wheel to the mounting surface. The reason I wanted to point that out is because by adding a spacer or shim you will be decreasing the offset.
Luke Pavlick
Sales Representative
ASE Certified Master Tech
For more info on any post
or to place an order please
call 800-428-8355 ext. 362
for on-line orders mention
my name in the previous
contact field for prompt
personal service.
www.tirerack.com
Luke Pavlick
personal service.
www.tirerack.com
I want to die peacefully in my sleep
Like my Grandfather
Not screaming and frightened like
the passengers in his car !!!
N
N
Originally posted by Luke@tirerack:
...The reason I wanted to point that out is because by adding a spacer or shim you will be decreasing the offset.
Unless of course your mounting point is aligned with the centerline of the wheel to begin with (initially 0 offset)...
ND SVT
2000 SVT (Black/Midnight Blue)
Patrick Offline OP
So basically I'll need to alter my wheel wells on the car in order to get rid of the rubbing, right? How about a heat gun to get the plastic soft enough to re-mold? That doesn't sound very hard (at least to me). Has anyone tried this before?
'98 SVT
You'll need to find a machine shop that can take some of the metal off the backpad (the part of the rim that meets the hub/rotor) to create the correct backspacing/offset.
Dion
98 SVT
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
Patrick Offline OP
After my last post, I realized that I was still thinking about offset backwards. Thanks for your patience everyone. I'm going to double-check if it's really rubbing on the inside/outside. If it's outside, I'm going to CAREFULLY bend the fenderlips back.
'98 SVT
Moderated by  1314_dup1
