#278342 04/27/01 02:17 AM
Found a really good deal on 205/50/16's (from a friend). Will these work ok on stock SVT wheels? I'm a tire idiot so please help.
Brian
2000 SVT Toreador Red
lightly modded
#181 of 2150
Born on Oct 1, 1999
AIM - nitrofish24
#278343 04/27/01 02:52 AM
Yes, they will fit the SVT wheel.
1991 GVR4
Lots of mods done.
#278344 04/29/01 10:14 PM
Your speedometer will be a little off since your sidewalls will be 5mm shorter on each side. (10mm total for .4 inches less than original diameter) I forget which way this will affect the readout, but this is discussed often so a search should turn up lots of info.
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17
'98 SVT
KKM / TH fix / Mobil 1 / Synth tranny cocktail / JVC LX-30 HU / 10" JL sub / Alpine V12 amp / Panther 199 wheels / Kuhmo Ecsta 215/45/17 / Bosch +4 / Ford Motorsport wires
#278345 04/29/01 11:31 PM
Smaller tires will cause the speedo to read fast. Check it out on the tire calculator at www.miata.net/garage/tirecalc.html
Personally, I would not want a smaller diameter tire on my SVT because of ground clearance problems.
Jim Johnson
98 SVT
Jim Johnson
98 SVT
Moderated by  1314_dup1
