Well, got my new tires installed today (Bridgestone RE730s). However, one the way home, I thought the car handled like crud. It didn't feel like the car wanted to go in the direction that I pointed it. It felt like I was driving my wife's SUV, the car didn't want to catch and turn.
When I got home, I let the car sit for three hours, then noticed that the air pressure in each was 40+psi. Would this have caused my sensation?
I'm going to adjust the pressure in the morning, and take it for a spin, but wanted some input from the experts. Thanks.
Ryan W.
1998 T-Red SVT E0 #634 (KKM)
Austin/Cedar Park, Texas
[This message has been edited by ryanwoodsvt (edited April 16, 2001).]
Ryan W.
1998 T-Red SVT E0 #634 (KKM, A6 Side Markers, +more)
CEG Registry - Austin/Cedar Park, Texas
ryanwood94 on AOL Instant Messenger
N
N
You've got it. Many tire shops use extra pressure when mounting the tire to help ensure that the bead seals well to the rim. Let your pressure down to normal in the a.m. and it should feel better.
It's more fun to drive a slow car fast than it is to drive a fast car slow.
99 SVT Contour
93 RX-7 R1
It depends. If you have a low profile tire they need higher pressure usually.Wide tires can also "track" more over road irregularities.
Andy V.
99 SE Sport
KKM,No Res,Duals
Semper Fidelis
Andy V.
99 SE Sport SGTO
KKM,No Res,Dual exh.
17" Cellos-225/45/17 Sumitomos
vannanthony@hotmail.com
Semper Fidelis
Once you have let the pressure down, and got it all sorted out, i would really like to hear what you think of those tyres, cause those are the ones i will most likely and up getting....
97 Zetec MTX
Boston FS80's in the front so far
Advent ACD45 (yeah, i know, but its all i could afford)
Reverse polarized RED indiglo style clock
Cb radio
97 Zetec MTX Sport
Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam)
Dual Fiamm air horns
Mk1 Mondeo Clear corners(and yes I made them fit....)
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com
AIM: AphexTwinGrin
I like the tires now that I have "fixed" the tire pressure (33f / 30r). I still am going to play with the pressure to find the optimal setting. The 33/30 was what I used with my Firestone SZ50s. However, I think the SZ50 handled a little better than the RE730, but I have a little more "testing" to do this week before I make a final judgement call.
Ryan W.
Ryan W.
Ryan- Give your tires a few hundred miles to scrub in. Guarantee they will feel much better.
Barry-2002 WRX-Sedona Red Pearl
K&N Air Filter- 225/50-16 SP5000's/Cusco Front Crossmember Brace/Borla Exhaust
JoeP Manual Boost Controller/Kartboy Solid Rear Endlinks
Samco Intercooler Hoses
Silencer Removed
Will Always Be Immaculate
4
4
Ryan, I have RE730's in 215/45/17 0n my Porsche 924S and they are fantastic. Very good feel on dry surface, and they don't seem to give up too much on wet. I like them.
Fun begins at 5000 rpm!
It is not uncommon for new tires to not have quite the same "on center" feel until they wear in a little. They will usually settle in better in a couple of thousand miles or less. Part if the condition is because the new tires are still very flat across the tread. As the edges wear on the front tires a little you should notice a difference. You will sometimes notice the same thing immediately after rotating the tires as well.
Jim Johnson
98 SVT
Jim Johnson
98 SVT
Thanks for all of the input. I guess I'll give the tires a chance, and let them break in before I start "complaining"...
Wow, I really like CEG, you guys/gals are GREAT!
Ryan W.
Ryan W.
Moderated by  1314_dup1
