Posts: 232 |
Ok, after reading a few posts today, I'm confused again. Some say that 225s work great on the stock SVT rims, and some say they rub. Other say that 215s are the max you can put on the car. I guess I'd like to change the discussion. What is causing the rub, is it the section width of the tire, or the tread width? Taking a look at different tires, they all seem to have different tread widths for the same section width (205/215/225). So, assuming that the section width is not the part that is rubbing, my question is what is the maximum width in INCHES for the tread that you can put on a stock SVT rim without rubbing? Table of various different tread widths. 205/55 R16 Bridgestone RE730 7.1" Firehawk SZ50 EP 6.5" BFG g-Force KDW 6.2" Goodyear Eagle HP+ 7.7" 215/50 R16 BFG g-Force KDW 7.2" 225/50 R16 Bridgestone RE730 7.9" Firehawk SZ50 EP 7.0" BFG g-Force KDW 7.2" Goodyear Eagle HP+ 8.3" Information take from TireRack Widths are tread widths. maximum tire widths for 205 (8.4"), 215 (8.6"), and 225 (9.2")
Thanks for all comments.
------------------ Ryan W. 1998 T-Red SVT E0 #634 (KKM) Austin/Cedar Park, Texas
[This message has been edited by ryanwoodsvt (edited March 27, 2001).]
Posts: 770 |
Actually, tread widths vary quite a bit from tire to tire. Compare the tread width from a Bridgestone S-02 Pole Position with that from a Yokohama AVS Sport or Bridgestone RE730 for example. You will see a notable variation.
The reason for the varying answers, IMHO, is the variable quality control, fit and finish, and factory tolerances/clearances on our Ford vehicles. The same wheel and tire fits a bit different on different Contours. Hell, I have heard of some people with rubbing right from the factory. Due to the fact that our cars do not have a ton of clearance under the fenders any variations there can mean the difference between rubbing and not rubbing.
My question... do we really need 225s on our cars? Fat rubber looks hot and all, but best handling comes from a well-chosen tire width. BMW has been catching a lot of flak from the automotive press lately for the optional 255s on their 330Ci/330i cars; they fit them to a lot of the cars they give out for road tests, and the verdict seems to be that they're just too much. Wider tires are also heavier...
T.
[This message has been edited by timd (edited March 27, 2001).]
Posts: 232 |
Originally posted by timd: My question... do we really need 225s on our cars? Fat rubber looks hot and all, but best handling comes from a well-chosen tire width. BMW has been catching a lot of flak from the automotive press lately for the optional 255s on their 330Ci/330i cars; they fit them to a lot of the cars they give out for road tests, and the verdict seems to be that they're just too much. Wider tires are also heavier...
Good question. There were two reasons why I wanted to move up to the 225. First was the looks of a wider tire, but second was performance. I assumed that if I got more rubber touching the road that it would increase grip. However, by your statement above, it might increase grip, but also increase weight, which could in return offset the advantage??? Is that what you're saying?
Posts: 770 |
I'm just saying that anything you do below the axle usually represents a compromise of some sort.  T.
Posts: 3,584 |
I had the 225's for my snow tires this winter, the Yokahama Guardex 600's and they DIDN'T rub! The clearance was checked while it was in the air AND on the ground...NO RUBBING  Roger R
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 8 |
Howdy, I have a 99 SVT with 225-50/16 Bridgestone RE730's and they fit just fine. I was going crazy just like you getting all confused so I know where you are coming from. The only thing is they are really bad in the snow if this is a concern. Good Luck
Posts: 85 |
I went a got a set of Dunlop SP5000 225/50/16 they fit fine no rubbing and i could tell a huge dif btw the stock g-force better ride and control. I noticed a huge gain of traction in the rain. Havent really drove it in the snow so couldent help ya their. If your looking for a new setup i strongly suggest the dunlops.
------------------ 00 svt silver #1254 of 2150 painted grills center resonater removed ------------------------- soon to be kkm air and oil cap eibach
Posts: 85 |
Pic of the dunlops [img] http://albums.photopoint.com/j/View?u=1416270&a=10591625&p=45120432[/img] ------------------ 00 svt silver #1254 of 2150 painted grills center resonater removed ------------------------- soon to be kkm air and oil cap eibach
Posts: 960 |
Be carefull when you look at those tread width stats, the rim width can affect it. A .5 inch increase/decrease in rim width will change tread contact width by .2 inch.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!" 87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock http://members.shaw.ca/neilmc/
