#277689 03/27/01 04:29 PM
Kevin B Offline OP
Do any of you know the factory 16" rim weight? I am about to purchase a set of OZ Superleggar rims weight just 8 kilos(17.6lbs)So I am venturing a guess here that that should be comparable to the 16" factory rim weight if not less.
[This message has been edited by Kevin B (edited March 27, 2001).]
#277690 03/27/01 04:48 PM
The Superleggeras are fantastically light
for a cast wheel. They're definitely quite
a bit lighter than stock. You can't really
go much lighter without buying forged wheels;
even the semi-solid-forged SSR GT-1 isn't as
light as the cast Superleggerra is.
Trust me, the M3 and S4 guys are DROOLING on
the Superleggerra, check their forums.
T.
BTW: If you have a '98 with the Cosworth-type
16" wheel, they're about 20-21 pounds or so.
[This message has been edited by timd (edited March 27, 2001).]
#277691 03/27/01 07:49 PM
Kevin B Offline OP
Thank you for the info, you guys helped me with a desicion, it either ACE Monaco 18" or the OZ Super Leggara. The ace was 25 LBS. Thanks Kevin
#277692 03/27/01 08:00 PM
CYS Offline
Too bad they won't be available till mid May and the S4 fitment will need spacers to clear the front brakes...not drooling so much now with the new info.
T.
#277693 03/27/01 09:39 PM
W
W
Hey Kevin are you planning on buying the 18in. wheel? As far as I know it won't be released for our bolt pattern for a few months. If you're getting the 17in, then the wheel weight is only 15.4 lbs. Great wheel, just waiting for the 18!
2000 SVT
silver/blue #1699 of 2150
14.793@94.88
Sho-Shop off road y-pipe for sale($75)
#277694 03/27/01 10:28 PM
CYS, definitely... but maybe an S4 fitment is
going to come along. Sucks about the delay in
production though... The BMW fitment came out
pretty quickly because AFAIK there's already
some people running them.
T.
#277695 03/28/01 07:50 AM
Kevin B Offline OP
No 18" promised by mid May. I think they sould be worth the wait. Apparently there will be a white weel with red lettering avialable in the summer.
cheers Kevin
#277696 03/28/01 11:17 PM
I'm not sure if this is really related but do yourselvers a favor...move the wheel weights to the inside, where all the breakdust builds up, it saves the marking up of the lip of your rims. The balancing is fine, I had no problems at 130 mph
Roger R
2000 SVT
#1253 of 2150
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
Moderated by  1314_dup1
