Posts: 67 |
anyone run this size. i'll most likely have 215/35 tires. thanks
96' LX (de-badged,konis,ground controls,injen intake,hose techniques kit,gauge pod,phantom gauges) more soon...
Posts: 149 |
Hey guys.... I need some help....
I want this size of rim... prolly running 215/40s
Do you think this will fit?? I have a 98 SVT, lowered with Eibach & Koni
Has ANYONE DONE THIS?? I need a quick reply!! Will the offset push it out toward the fenderwell or in toward the shocks/struts??
THANKS IN ADVANCE!! Jason
Posts: 2,657 |
A higher offset will move the wheel outwards.
Posts: 81 |
I'm running 17x7.5 with 45mm offset...the fit is perfect.
Posts: 1,627 |
Im running 18x7.5 with a 45 offset and 225/40 tires. Rubbing has a little to do with how much play you have in your suspension as well as the offset. The 45 offset is good but ive heard of Eibach H&R guys rubbing with this wheel but im running Ground Control and I have no rubbing at all, the suspension is stiff. I wouldnt suggest running anything but a 225/40 because as soon as you get them on your car youll see what I mean, the sidewall is THIN and youll probably hate yourself for getting anything less. But then again, the bigger the tire the more of a chance to rub. So good luck.
00 Black SVT #1545 Ground Control. Koni. 18" Konig Tantrum. More.
Posts: 149 |
how is your ride??? Thanks so much.... You've helped me with my dillema.....(SP) 5 Stars.... hehe Jason Check out http://www.envuscc.com
Posts: 1,444 |
i believe the lower the offset the more the wheel will stick out. most people run a 7.5 wheel w/ a 42 offset and 7 inch wheel w/ 40 offset. if u ran a 7.5 w/ 40 offset, it'll make the wheel stick out more and very likely rub. so 45offset w/ a 7.5 wheel should be pretty good. thats why our stock wheels are 48-49 offset and they dont stick out to the fender (they're also 6.5 inch wheels). to get the 6.5 to stick out to the fender you'd probably have to run a 38-40 offset.
AIM:omegazodiac
95 gl 99 contour svt #1750/2760 built 4/6/99 black/tan plates, not personalized (###-REV) amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
Posts: 536 |
I just put on 18x7.5 45 offset with 225/40's...I have eibach springs and haven't experienced any rubbing at all. As long as you have a high offset like a 45, which brings the wheel in more, you shouldn't have any problems...
Brian 1999 Contour SVT Green KKM, Dual 40 Series Flowmasters, SHO Shop Y Pipe, Removed Resonator, B&M Edge Shifter, Stainless Grills, Painted Rear Reflector, Green Underbody Neons, JSP Grand Touring Spoiler, Eibach Suspension, 18" Katana Tezzas, Pirelli Rubber, Graphics by http://www.clubconceptz.com brian8064@hotmail.com
