#277522 03/20/01 06:10 PM
jiako Offline OP
Hey guys whats up. I have 18" right now and i rub. but i have 225/40 on them. I am either lookin to get 17" millia migglia evos or if 18" w/ 215/35 don't rub i would most likely get them. so my main ? is for those of u that have 18" and have the car lowered do u rub AT ALL. if so did u get konis to help this out so u have less travel or was this still no help. please let me know i am goin to be making a decison very shortly....any info will be great. tia
alsp what width are ur rims and what is ur offset
jiako
98 svt silver
kkm true rev
18" mht qwans
wrapped w/eagle gsd2 225/40
Mesh grill
Eclipse headunit
Boston Acoutics (4)5X7
Kenwood Amp
(2) JL 12"
Mintex Pads
[This message has been edited by jiako (edited March 20, 2001).]
jiako|98 svt silver|kkm true rev|18" Enkie RS5 wrapped w/falken GRB FK451 215/40|Mesh grill|
Sony headunit|Boston Acoutics (4)5X7|Memphis 1100 amp|(2) JL 12W3|KVR X drilled rotors|35% tint|2.25" True Duals w/ Magnaflows| kkm pedals|LSD|Fidnaza Flywheel|Centerforce Dual Friction Clutch|FMS wires|Konis/Eibach|ESP bushings and Mounts|75MM PRO FLOW|DMD|Aluminum shifter & E-brake handle|SAFC|HID's and a few more cc's 196.1 and 183.4
#277523 03/20/01 08:12 PM
i am also looking but for 17. I just got the car and have no idea what i need to look for. All i know is 4 bolt. Please tell me more for my 98.5 se
[This message has been edited by hyperactiveme (edited March 20, 2001).]
1998 SE ATX
Dual exhaust
Body conversion
Nakamichi CD-40z HU
Sound by Crystal Mobile
Powered by a/d/s M860 AMP
My Ride
#277524 03/21/01 02:40 AM
You're likely looking for 17x7 wheel, 4x108mm
bolt pattern, offset in the 40-45 range (give
or take - check it, your SE may vary from my
numbers) ... and a good-looking design.
T.
#277525 03/25/01 06:13 AM
Koni's did the trick for me ... I was rubbing the fender in the back forever when I got my 18's, until I got the Koni's and made it a stiffer ride. Now, I do not rub on anything. I'd also recommend getting the Ground Control Coil Over kit so that you can customize your ride level. This combo worked wonders for my suspension department, and the car looks fat as hell now.
http://svtitan.com
-SVTweeter-
98.5 Black SVT
PIAA blue platinum fogs,CATZ MSC in factory fog holes 18" Chrome Neeper Titans
KKM Induction, 2 JL 12W6's, Rockford Power800@2, ROckford 200@4, (4) Pioneer horn 6x8's
5% tint around, side markers, blackened back Reflector, B&M shifter
shopping cart spoiler - I can fly baby!
new - Bassani Cat-back Exhaust
-SVTweeter-
http://svtitan.com - view the Ride!!!
98.5 Black SVT
PIAA blue platinum fogs,CATZ MSC in factory fog holes 18x7" Chrome Neeper Titans
KKM Induction, (4) 15 inch Solo-baric L7's in the trunk, (2)Earthquake PHD2 amps, Memphis 3004 powering (4) kicker 6.5 subs in doors,
Imaged Dynamic CD2 Horns powered by Memphis st150 amp.
5% tint around, side markers, Bassani exhaust, Ground Control Coil-overs w/ Eibachs,
Koni Struts & blackened back Reflector, B&M shifter
148.7 db May 6th - DB Drag
Yet to drag with new amps ... can't wait
#277526 03/25/01 03:35 PM
JOEYS fit 18x7.5's with a 42mm offset, 225/40-18 Parada's, no rub.
Dion
98 SVT
dion
98 SVT with some mods
http://communities.msn.com/contourstuff
#277527 03/25/01 08:27 PM
quick and maybe dumb question? 4 those of u that have big wheels(18's)and have dropped the car do u keep the fenderwells?(the black peices behind the wheel)also attached to the ground effects!
Anthony
98 black Csvt #630 of 6535
#277528 03/25/01 09:03 PM
Yes...
99' SVT
86' Toyota Pickup Beater - Tha Daily Driver
#277529 03/27/01 08:43 PM
jiako Offline OP
Hey dion do u know if he has a 98 or 99. from what i have heard ford changed the weather guarding on the 99s to accomadate for the wider tire(215). if u know of n e way i can get in touch with him so i can have a conversation i would be very thankful.
giacomo
jiako@aol.com
#277530 03/28/01 06:04 AM
giacomo
jiako@aol.com
Joey's car was a 99, had the newer fenderliner. It didn't rub anywhere in there or on the fenderlips. My car is a 98, it was rubbing but the fenderliner is still intact, but it still rubs the fenderlips. My car is using 18x8's with a 40mm offset. I have Koni's and H&R's, it helps a little to keep the tires off the fenders, but it's not a miracle, as they still rub on big hits/dips/heavy loads. Joey no longer has his Contour, he got purchased a 99 Cobra, and immediately slapped on 19" HRE's, 8.5's in front, 10.5's in the back.
Joey's email...
Joey2win@aol.com
Dion
98 SVT
dion
#277531 03/28/01 06:31 PM
V
V
Yes I rub with my 18s, but I guess I've learned to live with it.
98 SVTs
Cobra and E1
mods? (YES)
Moderated by  1314_dup1
