Anyone using 225/45 17's and not rubbing? I was just wondering what width of rim you were using and what offset you had on your wheels.
I want to run this size but don;t want to end up with any rubbing
Evan Groenke
1999 Silver Frost SVT #1919
183.9hp 163.7lb/ft tq @ the wheels
Now bitter at Ford
I wanted to run P225-45-17's but was told it would rub. I was also told that P225-50-16's would rub and they didn't, I had them on my OEM rims all winter and NO problems at all. I ended up going with the 215's which look good and all but I'll put on the 225's if I hear other wise in the future.
Roger R
2000 SVT
#1253 of 2150
Roger R
SVT/SHO Society SE MI rep
2000 CSVT #1253 of 2150
silver frost/midnight blue
2-8" dark blue racing stripes
Mequiars...simply the best!
"...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4"
USMondeo@aol.com
Is your car lowered? My car is lowered nearly 2" and I have 225-45-17 with 42mm offset and it rubs...Had to have the fender rolled. Someone I know with the same setup, but not lowered rubs minimally under heavy dips with lot's of weight in the car...
Peace: Moe - My Ride
=== 98 Mistyque LS (black) ===
  • Side Markers
  • Modded Headlights
  • SVT Bumper - rear
  • SVT Exhaust - no resonator
  • Suspension Kit
  • TH Fix
  • KKM True Rev
  • 17" Superior Tuners // GoodYear's 225-45-17
Peace! Moe
  • :::side markers::: :::modded headlights::: :::svt rear bumper::: :::svt exhaust - res-less::: :::bat side skirts::: :::suspension kit::: :::th fix::: :::kkm true rev::: :::17" superior tuners w/ goodyear's 225-45-17:::
[email:moeskii@hotmail.com]moeskii@hotmail.com[/email] - Pics: 98 Mystique LS
I suspect that a lot of if it will work or not depends on the offset and rim width on the wheels. 225/50R16 is a close fit with stock SVT wheels so there is not much room for error. You would definitely want to have the help of a tire shop that was willing to sell you something different if it did not fit when you actually tried it on the car.
Jim Johnson
98 SVT
Jim Johnson
98 SVT
Moderated by  1314_dup1
