I
I
Hi,
I have an European front license plate that I would like to mount. I can mount it on the existing bracket but it looks horrible because the license plate is much longer then the existing braket it self. Would it be possible to remove the existing braket and install an European braket style instead? Did anyone try this? do you have a pic? smile
This pic is from the banner from CEG, this is how I want it to look
Thank you
Ciao
Forza America!!! CT in the House!!!
98.5 Ford contour SVT
Alpine head unit, mbquart separates up front, 6x9 pioneers in the back. Running 500whats fosgate to two 10 kicker subs at 2ohms. Running 50x4 fosgate to the front and back speakers.
H
H
u should be able to. i had three holes when i removed my front license plate. i'm ordering bumper plugs for them. if your euro plate isn't tall enough it may not cover the top 3rd hole (assuming you have the 3 like me). otherwise you'll have to drill new holes. the 3 holes are like a triange, one on top and 2 on the bottom
AIM:omegazodiac
95 gl
99 contour svt #1750/2760
built 4/6/99
black/tan
plates, not personalized (###-REV)
amsoil series 2000 oil & filter~amsoil tranny fluid cocktail~tint: 35% windshield/front doors,20% rear window/rear doors~black oval/rear strip~nyceboi rear emblem~aussie grills~hella led sidemarkers~piaa superwhite low's~piaa extreme reverse lights~door dingless (knauberized)~hood liner removed~black '95 sail panels~trunk cargo net~mondeo hood struts~ford racing red 9mm wires~autolite double plat plugs~jensen hu~recontented dash clock(it rocks)~clifford ag4 security
I have one on my car,just go to Advanced Auto or Pep girls and get a cheap $3 licence bracket,they are plastic.but work great.I had the same prob you did and it worked out fine no need to even drill new holes just use the old holes.Its a universal type thingy. laugh
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
I
I
Thanks alot guys, I'll try it laugh
I had another quastion too. How do I remove the old plate mount? I tried it once, but I almost broke it off, so I stoped.
Thanks again
Ciao
after you take your license plate off there are three screws under there.just remove them.
Howard
June mods:
H
H
those three little plugs will likely break off. use a screwdriver to get under them and the heads will pop off.
AIM:omegazodiac
95 gl
built 4/6/99
black/tan
I
I
Thanks alot guys. I removed it, and the three little plastic plugs did break, oh well. I got an European braket mount from performance center of america for $11. I then went to Homedepot and bought 3screws that would fit right into the existing wholes (1 size larger then the existing screws), and it worked out great. I'll have to post a picture.
Thank alot again smile
Ciao
