The 98 1/2 (E1) SVT used the same size tire as your early 98 SVT did. They changed to the Cobra style wheel and to Goodyear Eagle F1 tires. The BF Goodrich G-force KDW in 215/50R16 was not original equipment until 99.
I have an early 98 SVT with 225/50R16 tires on it and they fit perfectly. They have been on for nearly 60,000 miles.
The fender liner rubbing issue did not happen until 99 and I believe that it was over some misbuilt liners. The replacement liners did provide more clearance but you probably will not need them for 215/50R16 or 225/50R16 tires on your early 98. I have never had a tire rubbing issue, even with four people and luggage in the car for a family trip.
Jim Johnson
98 SVT
Originally posted by T.J. Fontana:
I have a 98 SVT that came with the 205-50/16 Goodyear GS-C's. Now I remember back then they had the 98.5 that redid the valving in the struts and also came out with the 215-50/16 G-Force tires. Then they said they had to do some inner fender well modifications does anyone know exactly what they did in the fender wells if anything or anyone that has put 215-50/16 on the 98 SVT wheels? Thanks.
