#276408 01/16/01 06:28 PM
C.SVT Offline OP
I've decided to get either the Potenza RE730 with are $107.00 ,or the Kumho ECTA Supra 712 for $81.00 a tire, both tires are 225/50zr/16, I dont drive to hard in corners , I'm looking for a tire that would last a little longer then the G-Force KDW's but still give me great straight line traction in dry and wet,please give me any thoughts on what tires to get or any other tires you might recommend
1999 Contour SVT, Black W/midnight blue
True-REV sports induction
B&M short throw shifter
Bassani exhaust
Bassani exhaust
Bridgestone Potenza,s
http://pages.prodigy.net/nascar1cs
#276409 01/16/01 06:32 PM
CYS Offline
I thought the KDWs had a tread wear rating of 300 - which is probably the highest rating I have seen in ultra high performance tires.
#276410 01/16/01 07:57 PM
N
NMC Offline
N
Go for the KDWS's with a treadwear of 400 in a 205/55 R 16. Better wet grip and smoother ride. Difference in actual tread width is negligible.
96LX/24V/ATX/Midnight Red/A4 repeaters/SVT exhaust/KKM/65mm throttlebody/SVTsprings and ST200 struts/SE rockers and BAT spoiler/BAT 19mm swaybar/urethane bushings/Kenwood 7 speaker syst./E1 SVT brakes w Powerslot rotors/9005 lowbeams/885 fogs/50% tint/Michelin XM+S 130's for winter/E1's with gForces for summer...and now "New Paint!!"
87 Renault GTA convertible/2.0l/mtx/Sony sound/otherwise stock
http://members.shaw.ca/neilmc/
#276411 01/16/01 09:17 PM
In general, UTQG treadwear ratings are useful
in comparing tires from the same manufacturer
but are not absolutely reliable to compare a
given tire to one from another manufacturer.
UTQG tests are done within a manufacturer's
own line-up of tires, so those numbers tend
to reflect the nature of the brand line-up as
a whole, not just one tire.
T.
#276412 01/16/01 10:33 PM
The Re730's are the number 1 Ultra High Performance tire on the market today for good reason. The Kumho's do not perform nearly to the level of the KDW's which can't keep up with the 730's. Taka a good look at the Dunlop Sport 9000's which is a Maximum Performance tire with a 280 AA A rating.
Thanks, Luke
Luke Pavlick
Performance Specialist
ASE Certified Master Tech
for more info or to place orders please call 800-428-8355 ext. 362
Luke Pavlick
Sales Representative
For more info on any post
or to place an order please
for on-line orders mention
my name in the previous
contact field for prompt
personal service.
www.tirerack.com
I want to die peacefully in my sleep
Like my Grandfather
Not screaming and frightened like
the passengers in his car !!!
#276413 01/17/01 08:30 AM
Toyo T1-s period. Treadwear rating of 280...very high for ultra high performance, but they didn't seem like it. GREAT handling tire the best one i've tried yet. The sidewalls on this tire are much more ridgid than any other tire I've found. I've owned Goodyear GS-c's, Michelin pilots and Currently Bridgstone S0-2 Pole Positions, all of which blow compared to the toyo's, I will definetly go back to them after I wear out the S0-2's in a few more thousand miles. Oh some of the other tires had better grip at the start but none handled better or lasted longer. Check them out at www.toyo.com cool tread pattern too!!
rainshdw
98EO SVT, Black #30
Born on 25 March 1997
You don't like it???...GTFO!
rainshdw
#276414 01/17/01 06:05 PM
C.SVT Offline OP
Thanks for all of your opions and i'll have to check out those Toyos
Bassani exhaust
#276415 01/17/01 10:00 PM
Luke, you're saying that the RE730 performs
better than the KDW (I'm talking about the
summer-only KDW, not the all-season KDWS). I
am surprised by this... I had not bothered to
even consider the RE730 and was going to go
straight for the SO-2 Pole Position, SP Sport
9000, or similar summer-only tire with strong
wet performance. F1 GS-D2 is also on the list
of course.
T.
#276416 01/17/01 10:27 PM
"The Re730's are the number 1 Ultra High Performance tire on the market today for good reason. The Kumho's do not perform nearly to the level of the KDW's which can't keep up with the 730's.'
Luke, how do you know this? Comparison test?
Dan
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
#276417 01/18/01 05:57 AM
Toyo's are the BOMB dude!!!!!
98EO SVT, Black #30
rainshdw
Moderated by  1314_dup1
