Posts: 45 |
I have a 99 contour with stock tires (205/60R15) Firehawk. I would like to replace them with better tires. I would like to go to a tire size of 215/60R15. Would this give me a problem with the tires rubbing? And what tires would you recomend? Thanks.
Posts: 91 |
The 215/60/15 should fit with no problem, The 99'-00' SVT's come with 215/50/16 tires, So the overall diameter would be close to the same, What type of tire are you looking for , all-season ,or high performance.
Posts: 170 |
I replaced my 215/50/16 stock tires with 225/45/16 with no rubbing issues whatsoever!!  ------------------ 99 SVT K+N 4/99-35% 3M tint on all 5 windows 6/99-Rear valance painted silver 10/00-Painted all the grilles silver as well! 10/00-D & T short shifter 225/45/16 Kuhmo Ecsta 712s The SVT is like....numbered and stuff-#1079/2760
99 SVT K+N 4/99-35% 3M tint on all 5 windows 6/99-Rear valance painted silver 10/00-Painted all the grilles silver as well! 10/00-D & T short shifter 225/45/16 Kuhmo Ecsta 712s 3/01-Red Ford Emblems with Black flames
Posts: 91 |
Travis how do you like your kuhmo's, are the 225/45/16 a better match for our cars then kuhmo's 225/50/16, also tirerack has the 225/45/16 for use with rims 7.0 to 8.5 inch and we have 6.5 inch rims, so how do they look on the SVT rims , that is if you still using the stock rims, and how do they compare to the KDW's
------------------ 1999 Contour SVT, Black W/midnight blue True-REV sports induction B&M short throw shifter Bassani exhaust
Posts: 3,562 |
Originally posted by Frank De Simone: I have a 99 contour with stock tires (205/60R15) Firehawk. I would like to replace them with better tires. I would like to go to a tire size of 215/60R15. Would this give me a problem with the tires rubbing? And what tires would you recomend? Thanks. I have 225/50/15's on the stock alloys, no problem what so ever. 215/60's are a little taller though... ------------------ Brad "supercharged closet" Noon '99 SE MTX, many mods http://www.bnmotorsports.com
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 587 |
go to www.toyo.com they have a chart there that shows tire sizes and tire diameters. look at your original tire diameter and find a wider tire within a few inches and you'll be fine, plus sizing your wheel will help also, but that cost's alot more money
98EO SVT, Black #30 Born on 25 March 1997 You don't like it???...GTFO! rainshdw
Posts: 422 |
215/60/15 will work just fine. They fill in the wheel well really well. I was wondering if anyone has ever tried a 225/60/15? Does it clear the the struts?
------------------ 98' Black Contour Sport GL Zetec ATX KKM,No Res,Dynomax Muffler,Side Markers Zetec and Limited Edition Emblems,Custom Headlamp & Taillight covers,Tinted windows,Ram Air Induction into KKM,Front Strut Tower Brace,Custom Upper and Lower Mesh grills,885 Fog lamp bulbs,Rear Dome light,Ventshades,Remote Start,Remote Headlamp & Taillamp Strobes,Large Stereo system
98' Black Contour Sport GL Zetec ATX KKM;No Res;Dynomax Muffler;Custome pedal kit;Custom ATX shifter;A-Pillar Gauge Pod w/Voltmeter,A/F Ratio,Oil Pressure Gauges;Side Markers;Zetec and Limited Edition Emblems;Custom Headlamp & Taillight covers;Tinted windows;Ram Air Induction into KKM;Front Strut Tower Brace;Custom Upper and Lower Mesh grills;885 Fog lamp bulbs;Rear Dome light;Ventshades;Remote Start;Headlamp & Taillamp Strobes;Stereo system
matthewbounds@hotmail.com
Anonymous
Unregistered
Anonymous
Unregistered
Originally posted by Travis: I replaced my 215/50/16 stock tires with 225/45/16 with no rubbing issues whatsoever!!
thanks for the info, i'm getting 225/50/16's tomorrow, crossing my fingers - hope they fit!!
