Anonymous
Unregistered
Anonymous
Unregistered
I'm out of the stock BF Goodrich tires on my 99 SVT. I got just 26K miles out of them. I'd prefer to save a little $$$ on my next purchase and maybe get a little more mileage. Can I put 225 50 16s on the stock rims (will they fit OK?). I was thinking either the Pirelli P7000 SS or the Dunlop SP 8000s. Thanks for your help. Happy Holidays!
Shaww,
If your trying to get more miles why bother going wider. You going to sacrifice more grip by going to a lower rated tire than you can gain by going one size wider. Just my two cents.
-Andy
-Andy Watson
'99 Silver Frost SVT
205/55/16 KDWS
If I weren't poor,
so much more.
Andy Watson
'99 Silver SVT #2397| DOB 07/29/99
Graci!
American Iron Shoot Out - Event Promoter!
Check it out, we need your input!
Www Dot American Iron Shoot Out Dot Com
9
9
225/50/16'S will not fit into the wheel well of the car. Its too wide, in fact it will rub against the side of it. NOT too good!!! A good set of tires would be Kuhmo's and for $78 bucks per tire for W-rated its a great deal.
Anonymous
Unregistered
Anonymous
Unregistered
Thanks to all for your inputs! After making several calls locally, no one had the g-Forces in stock. I went to the tirerack.com and found 4 for $90 ea. and they are on their way. I talked to a manager of a Big O store who was familar with my drive to work (40 miles one way, most on a very crooked road) and he was impressed with the 26K miles I got from the original tires. I like the fact I bought an American made product.
Anonymous
Unregistered
Anonymous
Unregistered
Yeah, Dude! 26k is not bad at all. Some people report getting less than 20k out of their KDW's. When you consider that this is a helluva nice tire, $90 is a good deal. Sure you could get more miles per dollar out of a touring tire, but it wouldn't be anywhere NEAR as much fun!!
97 Contour Sport V6-ATX/KKM/JET chip/ASP UDP/rear STB/rear dome lamp/SVT 16" wheels
BFG G-force KDW's/LeBra/Fogs-as-DRLs/battery relocation/Bosch +4's/Magnecor wires
I got 38K miles on my first set and still had tread left but winter is here and I got new ones.
99 SVT Black/Tan #1090/2760
38K Miles
Mobil1 5-30
Ford Synth MTX # XT-M5-QS
Side Markers
Locking Lugs
Black Sail Panels
Aluminum Gas Filler Door
Cup Holders
New BFG KDW's
82K Miles.......B&M Edge Shifter
Mobil1 5-30.....Side Markers
Locking Lugs....Cup Holders
Black Sail Panels...TH Fix
BS Potenza S-03's
KVR Cross Drilled Rotors + Pads
Dual Mode Damper - soon
Clarion head unit
Pioneer 2-ways
16K for me and they are due for new ones which are on the way!
99 SVT
K+N
35% 3M tint on all 5 windows
Rear valance painted silver
Painted all the grilles silver as well!
D & T short shifter
Special lightweight tires!/Soon to get Kuhmo tires!
The SVT is like....numbered and stuff-#1079/2760
99 SVT
K+N
4/99-35% 3M tint on all 5 windows
6/99-Rear valance painted silver
10/00-Painted all the grilles silver as well!
10/00-D & T short shifter
225/45/16 Kuhmo Ecsta 712s
3/01-Red Ford Emblems with Black flames
24k with the stock bfg's. 400 miles on the new ones from TireRack at $90 dollars for each also!!!!
Sincerely
Merlin
Kansas City CEG
99 SVT Black #1210
KKM intake/Custom Exhaust
Fog light Conversion/20%tint
Dyno'd = 163.8 HP, 148.5 FT/LBS
1/4 15.564@ 88.24 mph
--New =CHIP--
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
Moderated by  1314_dup1
