Posts: 5,296 |
After seeing how the MTX-75 shifts like on a 2000 Contour, I decided that I might try to do the tranny cocktail. But, I'd like to know if the friction modifier is really necessary? Anyone tried to use just ATF fluid without the friction modifier? I have a gut feeling that local dealers don't stock these things.
Posts: 3,598 |
Any Ford dealer with a parts department will stock friction modifier. It is as common there as 80W90 gear oil and SAE5W30 motor oil.
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 618 |
Your '95 will never shift like a 2000. They have the cables and you have rod shift. Tranny cocktail helps, alot in the summer, and somewhat in the winter (here in Cleveland), but I still need to let the tranny warm up before it likes 2nd gear shifts in the winter. Some have done synthetic ATX fluid without fric. mod. I used it. You could also buy the new MTX fluid from Ford. It is gold in color. No need for the modifier in this fluid. It is expensive stuff though. Was about $15 a bottle. Try doing some searches on the newer MTX fluid. It hasn't been talked about in a while. The '00 probably had the new MTX fluid in it.
GOD BLESS AMERICA!!!
Ted tdavidk76@hotmail.com '95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX. Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods. Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
Posts: 38 |
The friction modifier works great, IMO.
1st i upgraded to the Ford (Motorcraft?) synthetic ATF & noticed only very minor improvement in smoothness. A week later i removed 2 oz. of ATF & replaced it w/ 2 oz. of the friction modifier (in-stock at local dealer). Made all the difference in the world. Great stuff!
jay bass deltaman@mindspring.com jb@thedelta.com '99 SVT Contour (tropic green/tan) 557 of 2760
Posts: 5,296 |
Damn! I got all excited because I can finally make my car shift like the DSM's gearbox (which the 2000 I drove felt like). But isn't rod shift mechanism supposed to be better than cable shift mechanism though? Originally posted by tdavidk: Your '95 will never shift like a 2000. They have the cables and you have rod shift.
Posts: 38 |
yup, IMO.
Posts: 716 |
uhm.... should I be scared of this modifier?
(everyone lol at my stupid joke)
-Chris
Chris Hinds AIM:CJ111010 1998 Contour GL Duratec 5-Spd #565/???? 15.610 @ 89.62mph And I payed for it all myself
