Posts: 163 |
What kind of lifetime do the BFG KDW's have? What kind of mileage are people getting out of them before replacing them?
------------------ 99 Silver SVT
99 Silver SVT #1264/2760 SVT124@aol.com
Posts: 559 |
I have 34K on mine and plan on getting 2 more months out of them before the snow. I also am curious about the (KDWS) version for winter.
99 SVT Black/Tan
99 SVT Black/Tan #1090/2760 82K Miles.......B&M Edge Shifter Mobil1 5-30.....Side Markers Ford Synth MTX # XT-M5-QS Locking Lugs....Cup Holders Black Sail Panels...TH Fix Aluminum Gas Filler Door BS Potenza S-03's KVR Cross Drilled Rotors + Pads Dual Mode Damper - soon Clarion head unit Pioneer 2-ways
Posts: 2,112 |
I've put about 10k miles on mine and they're about 3/5ths way done. I don't think the 300 treadwear indicator means that much. Probably going to go with Bridgestone RE730s or Firestone SZ50 EPs, assuming the NHTSA doesn't open an investigation on them too. I also have the Yokohama AVS Sports and and AVS-S1's in mind. ------------------ Louis Wang Sugar Land, TX 1998 Black E0 #3826 http://web.wtez.net/tw57472
Posts: 170 |
After 15K I need new tires. I am very hard on tires though. I can't tell you how many times rubber has been left on the street sliding through corners and other extremely fun stuff this car "tells" you to do!!!
------------------ 99 SVT K+N 35% 3M tint on all 5 windows Rear valance painted silver Special lightweight tires! "Anything is legal as long as you don't get caught"
99 SVT K+N 4/99-35% 3M tint on all 5 windows 6/99-Rear valance painted silver 10/00-Painted all the grilles silver as well! 10/00-D & T short shifter 225/45/16 Kuhmo Ecsta 712s 3/01-Red Ford Emblems with Black flames
The SVT is like....numbered and stuff-#1079/2760
Posts: 76 |
I currently have 33K on mine. I probably would have made 40K if my alignment had not gone out and warped a couple of the tires.
------------------ Scott Doughtie 99 SVT, Tropic Green KKM, 73mm MAF ASP Pulley Redline Synthetics Side Markers Recontented Clock Added Rear Dome Light Recontented Sunroof Switch
Scott Doughtie 99 SVT, Tropic Green KKM, 73mm MAF ASP Pulley Redline Synthetics Side Markers Recontented Clock Rear Dome Light Lighted Sunroof Switch Mesh Grilling Motorsport 9mm Wires Kumho Ecsta Supra 712s Bosch Platinum +4s
Posts: 92 |
I have the KDW's on my Cougar, and I do drive them very hard, and got about 13k out of them. Two main reasons, I autocrossed on them(8 times), and my access road to work is like sand paper(well it was they just repaved it) and I drive hard on it.
I will probably get another set of KDW's although next season I'll have a dedicated set of tires for autoxing so I won't be beating my road tires to hell.
99 Cougar V6 Tourmaline Green: MTX, KKM, Borla Dual...
Anonymous
Unregistered
Anonymous
Unregistered
I've got 20K on mine and they are due. I'm going to get another set of KDWs.
