Posts: 88 |
I was wondering what everyone has used to get rid of the nasty black slinky looking thing from the air box use to be to the chamber? Can you take that chamber off and put a straight pipe to sensor to filter element? Any ideas or guidance?
98 Contour SE ATX Polished Weapon*R Hyper Intake all interior lights blue. Rockford Fosgate in all doors two 12" Fosgate Subs pushed by a RF punch 200 JVC head unit & 12 disc changer Mesh Grille top and bottom Micro projection lights up front Cobra eyes Hood lights Strobe lights in Headlights Tinted all around Factory 12 spoke rims Stock rims, not sure what to put on !!! website http://www.fenonmenon2.20m.com
Posts: 2,263 |
check out the BAT's polished aluminum air inlet pipe.
Jim Hahn 1996 T-Red Contour SE 2002 Black Mazda MP5 Latest mods: sho shop off road y-pipe
Posts: 1,071 |
Originally posted by Fenonmenon2: I was wondering what everyone has used to get rid of the nasty black slinky looking thing from the air box use to be to the chamber? Can you take that chamber off and put a straight pipe to sensor to filter element? Any ideas or guidance? How about a Vortech?
Speed kills, but it beats going slow! Simon Langley Black 98 SVT EO (#2119 of 6535) 269.3 FWHP, 195.4 TQ 14.123 @ 97.36 All go, and no show! Vortech, Quaife, Driveshaft Shop Stage II axles, Magnecore Wires, Custom True Dual Exhaust. CDW-27 1/4 Mile Registry
Posts: 88 |
So is it a pipe all the way from the filter element & sensor all the way to the chamber?
Posts: 2,263 |
Posts: 88 |
that is nice That is BAT correct? I will look into it, I am tired of that ugly black tube! Yuck! Has anyone removed that chamber all the way? What happens if I do remove it ? I have no idea thats why I am asking.
Posts: 1,701 |
This is an ABS plastic cone made to fit the TB on one side and the MAF on the other. I applied pipe insulation to help keep it a bit cooler. The air pipe is over 9" long so the MAF bolts directly to the cone filter. (No adaptor needed) The outside end of the cone filter is about 2" from the fenderwell opening and external air.
Posts: 763 |
 here is mine
Posts: 763 |
Posts: 763 |
http://home.earthlink.net/~jhoaltsprint01/index.html go hear to see the pipe on my car
