i want the sides to come on only when the turn signal is flashing , i cant figure out the wiring, i hooked the white wire to the blue & orange wire of the turn signal, and the black ground to the black ground of the turn signal but the light flashes really fast and the light in the dash stays on, what am i doing wrong? I can just splice in like the diagram shows that someone has, right?
thanks.
1998.5 silver frost svt
resonator removed,
Alpine 7875 h.u. (sweet),
4 Blaupunkt 4 way 6x8's
clear sidemarkers,
PAA Offline
I would like to know how to set mine up like that too. I installed my sidemarkers months ago but haven't wired them yet.
I am working on my car this weekend so I could do the wiring also, if I had some instructions.
'98 SE Sport
Fog light mod and sidemarkers
No significant power mod
that sounds right, it should work fine like that. try grounding the sidemarker to the car body, see if that works.
-Louis
1998 Black E0 #3826, lightly modded
my interior turn lite should not stay on though right? and do they normally flash really fast?
resonator removed,
clear sidemarkers,
PAA Offline
I always thought that if you have a light on the dash flashing really fast that meant that you had a bulb out.
Do I need any resistors or diodes to hook up between the sidemarker and lights?
'98 SE Sport
Did you have the front turn signal hooked up when you were testing? If you didn't, that would explain the "turbo blinker" that you are experiencing. If you do a search on this topic you'll find the schematic and it's quite easy to follow. If not, let me know I might have it saved somewhere on my comp and could email it to you if I can find it.
Chuck cwc3@yahoo.com
'98.5 silver SVT, #6226 of 6535,
24mm AAM "aussiebar", KKM intake, custom y-pipe w/ high flow cat,
custom cat-back w/ Magnaflow race series mufflers w/ 4" tips, Bosch
+4s, FMS 9mm blue wires, IAT mod, Bullit fuel door, 35% tint all
around, APC clear sidemarkers, PIAA 510 driving lights, Cuzo
headlights, "carbon" sail panels, chopped shifter w/ Richbrook knob,
OBX pedal pads, "Bluepoint" Key Largo HU, Pioneer TS-A6955 6x9 3-way speakers in the doors, Precision Power PPI2240 amp, Xtant X410 10" sub in bandpass enclosure.
your not hooking the white wire to the blue AND orange wire at the same time are you?
Just the one.! laugh
Howard
1998 Silverfrost SVT #1612
June mods:
17" ADR RS Limited Limix Wheels
with 215/45/17 Yokohama AVS Sports
Anthony
98 black Csvt #630 of 6535
PAA Offline
Thanks for the schematic. Since it will be raining all weekend here in dallas I will be in the garage messing with the tour instead of at the lake.
Thanks
'98 SE Sport
