Posts: 35 |
I am getting ready to buy some 'R' compound tires for Auto-X and would like some help.
Has anyone tried the Kuhmo Ecsta 700 tire yet? What is the difference between them and the Victoracer 700?
I see that they are the same price (full tread, heat cycled) but don't know what the difference is.
I will be buying within the next month so I can start useing them in the middle of May.
John
John Alessi Torredor Red #1915 of 2150 Born 21Jan2000 G/S No serious mods allowed
Posts: 213 |
i have those tires and i like them...
Posts: 219 |
SVT2000Contour, From information I have, the Victoracer might be the better choice for heavy cars like ours. The Ecsta 700 performs at different slip angles and behaves better on lighter cars. The Victoracers allow a little bit of slip and still maintain some grip. The Ecsta 700 once it starts slipping has no grip. This information came from people in Camaro's and Honda's who have driven on both tires. Check with Tirerack for the latest information. HTH
Respectfully, Andy Hohl
Posts: 477 |
track down L8 Apexing Aussie, he has Kumho tires
1996 Contour SE Red V6 MTX 1995 Contour LX Champaign V6 ATX (my wife's beater) SuperChip | KKM Intake | Ford Motorsport 9mm Wires | Bosch +4's | Mobil 1 | No Resonator | Knauberized Doors | JSP Custom Wing | Re-wired Fogs | Red Painted Calipers | 98+ Sail Panels | Vuncannon Alarm | Lighted Moonroof Switch | Pioneer Head-unit | Pioneer 6x8's
Posts: 460 |
What about using some Hoosier R3S03 tires for OpenTrack events and/or club racing on road courses?
I will be getting some 16" racing rims to go along with some new R compound tires. And will only use them on the track.
Looking for comments.....
Nikolas
1999 Mercury Cougar V6 KKM Intake,SVT TB, SVT Upper/Lower, 19lb injectors, Diablo Chip, MSDS Headers, Custom Exhaust, B&M Short Shifter, Progress Lowering Springs, 18" Axis TC's, OMP Strut Bar, AAM 24mm Rear Sway Bar, Koni Struts
15.09 @ 91.54(corrected, pre-SVT conversion, DiabloChip, and Injectors)
Posts: 219 |
Depending on the length of the event, you may go through a set of Hoosiers each time. They have good grip, short life. HTH
Posts: 293 |
Unless you flat spot them, Hoosiers are good for 6 to 10 heat cycles. Normally a heat cycle is considered one autocross event or one track session. Heavier cars and cars harder on tires (like FWD) may only get 3 to 5 heat cycles. A lot depends on driver style.
John Coffey johnc@betamotorsports.com
Posts: 460 |
IF that is the case, then maybe I shouldnt go with them, because many of the track events I will be going to, each group of cars gets 3-5 sessions a day, with each session running 20-30 minutes.
It looks as though the VictoRacer may be the tire of choice then.
Nikolas
Posts: 878 |
I avoid the Hoosiers, because what I've heard is that they are vulnerable to flat-spotting in the hands of ham-fisted newbies like me. I'll stick with the cheaper solutions, at least until there's a national championship on the line (as if...)
"Function before fashion."
'96 Contour SE
Posts: 825 |
Originally posted by SVTwannabeme: i am running 712 ecsta tires, im not sure if you looking for the 700 tire itself or the 700 series. i have 215 45 r17 and i like them alot, especially for the price. I ran yokoham A520's at a 40 and and the khumos are a smoother ride. also i notice a corner that i normally take the yoko tires broke loose on them.. started to squeel.. havnt noticed that on the khumos I too have Ecsta 712's but I belive the discussion here is about Kuhmo and Hoosier race tires, not street tires.
Matthew W. Campbell-- bigMoney Racing -- 1999 SVT #220 "NT4UA" /O.Z. Crono Evo\'s/ /Rear Deck Sub/ -- 1972 Chevrolet C/10 Custom Deluxe-- 1980 Camaro in fewer pieces-- "If I had invested...in IBM or something like that, I would certainly have been wealthy within a decade. Instead, I bought a Porsche...and got a life" Leon Mandel
