Posts: 1,195 |
i'd personally want the hood pretty clean, and free of vents and scoops, the ones pictured would be fine, but i would most likely just use them as a starting point for cutting the wholes to fit escort RS cosworth vents....
97 Zetec MTX Sport Esslinger UDP; Nology HotWires and BERU Silverstones; Sylvania Silverstars (high beam in low beam) Dual Fiamm air horns Mk1 Mondeo Clear corners(and yes I made them fit....) Boston FS80's in the front
Micah's PRE98 SVT front bumper, W/ Mirko splitter(yet to be painted)
Rally drivers do it sideways......
Email: Roknut@linkline.com AIM: AphexTwinGrin
Posts: 128 |
I'm in let me know when you need the money.
98 GREEN SE RACTIVE. 75 NOS. KONIG WHEELS. ST200 UPPER INTAKE MANIFOLD. SVT TB. BOCH +4 PLUGS. 9MM PLUG WIRES. AUDIOBAHN, ALPINE, PLS2 INSIDE. AUTO METER. SVT BODY KIT. SVT GAUGE CLUSTER WITH INDIGLOW GAUGES. MORE COMING SOON.
Posts: 162 |
Yes, design is important. NACA ducts, the 'reverse scoops' are either nonfunctional or worse (open and leaky). A fresh air intake setup might be nice ('ram air'?). Other than that, a slightly bubbled hood would help airflow in the compartment and keep the intake cooler. One would think an improvement of the orig hood was in order.
98 CSVT, basic mod's, my slowest car yet but still faster than the wife's Talon Tsi AWD. Not by much, though. Now if I could get the back wheels to do something....
Posts: 1,036 |
Reverse scoops are not nonfunctional... They allow much of the heat to escape the engine bay. Cosworth would not be using them for years if they were "nonfunctional and leaky". Frontward scoops cannot be used for "ram air" unless the intake is specifically designed for such a purpose. With all that air coming in its just going to increase drag and blow the air all around the engine compartment with very little "ramming" into the air filter.
98 E0 Silver SVT KKM - Bassani - MSDS - BAT - ES - Unorthodox - HID - Dyna-batt - Koni - Ground Control - 17" MAS Italy Rodger - Quaife - Fidanza
"Every easy girl I have been with has been either a hosebeast or a headcase" - Pete D
Posts: 181 |
I am a strong possible for a pre98 hood
Paul Woodward 95 SE V6 MTX KKM, 8mm plug wires, no badges, 75HP shot of THE JUICE, B&M T-Handle Shift Knob, MOMO Aluminum Pedals, Richbrooke e-brake handle, A-Pillar with Phantom air-fuel ratio gauge, voltmeter, and oil pressure gauge, Unorthodox Racing Pulley, In dash 5" TV screen, playstation one, Apex DVD player, Digital TV tuner. Coming soon, Sho-shop y pipe and 2.5 inch single pipe exhaust
Dyslexic man sells soul to Santa... Film at 11
Posts: 1,022 |
is there anyone else? or is this all I am working with?
Micah
97 Lx 3.0 MTX lighten flywheel,udp's,kkm,no cat,true dual,svt tb,80mm maf,19lb injectors,S-afc,svt ground effects, 18's w/ yoko 215/40/18,front/rear strut braces,eibachs,egr gasket mod,
15.2@94 with 2 people in the car and a bad 1st gear wanna race?
micah_trudell@hotmail.com
Posts: 1,036 |
I have sent you a PM to let you know I am interested...
Posts: 661 |
Was the 12-15 lbs quoted the weight of the new CF hood? Or is that how much weight we lose by changing to a CF hood?
Technical Director/Co-Owner Performance Fords-check out our new throttle body service 95 SE with lots of custom 1 off mods. All design, fabrication and installation by owner.
Posts: 620 |
Me got new JOb, me got more money......me in! :-) post98..... but i have to see it first.
SVT EMBLEM MOD HERE :::96:C:LX:::Black 2.5L ATX "my beater" - Shaved ? badgeless ? SE rocker panels :::99:SVT:C::: #2566 of 2760 T-RED/TAN "the bitçh" Brullen Cat-back w/ 3.5" angle-cut tips ? BAT European Suspension ? AFE Filter ? CnL 73mm MAF ? Diablosport Chip :MNQ3: ? Mirko front spilter ? Apexi SAFC (i'm scared to install! anyone in Norcal wanna help me?) ..::nyceboicreations.com::.. email:junkmail@nyceboicreations.com
Posts: 107 |
The cable securing the springs on my garage door snapped and the springs came crashing down on my hood. The apartment will pay for replacement so I AM IN! Let me know how much and when.
justSVT My Tour is a cross breed.
