Posts: 1,268 |
Yes! Let us know. I get paid tomorrow and I need to know before I spend all my money on other stuff...
-Ken V. psycho_bass@hotmail.com My Car
Posts: 618 |
Are these the ones that don't require any drill and tap? If so I am intested!
GOD BLESS AMERICA!!!
Ted tdavidk76@hotmail.com '95 SE • DOB-4/20/95 • every option • Champagne • Duratec • MTX. Mods: Taylor wires • Bosch +4 • Eibach/Sachs Super Gas (half done) • rear BAT urethane bushings • SVT air box (thanx Dom!) • fogs w/parks • 885 50w fog bulbs • Ray's THF • rear dome • lighted moonroof switch(thanx again Dom!) • tranny cocktail • minor stereo mods. Yet to install: Front Eibach/Sachs • Front BAT urethane swaybar bushings.
Posts: 2,657 |
Originally posted by tdavidk: Are these the ones that don't require any drill and tap? If so I am intested!  I doubt it.
Posts: 412 |
I'm in, as long as I don't need to drill or crap like that... Contact me with details. Alleyway28@excite.com Thanks, Marc Oh, Yeah... Are they the chrome ones??
1998.5 SVT
Posts: 38 |
I'm in, as advised in a private email to you. What is the status, please?
jay bass deltaman@mindspring.com jb@thedelta.com '99 SVT Contour (tropic green/tan) 557 of 2760
Posts: 108 |
I'm in. I have sent an e-mail to you for the info.
1996 V6 se mtx KKM Intake Superchip Dual Exhaust SVT Flywheel BAT Intake Pipe Guage Pod Pillar w/volt meter,oil temp. & oil pressure Bullitt Fuel Door dpa43@hotmail.com
Posts: 804 |
I'm in...sent email as requested but didn't see my "name" in your roster. Confirm you got my email? Thanx!
-Rob- '98 E0 Contour SVT #897, T-Red. FOR SALE: '98 E0 CSVT #2663 SilverFrost; stock & in very good condition. $7,800 KKM & BAT Intake Pipe, DIY cool air intake, Resonator deleted, TH fix; short shifter, rear spoiler, hood struts, fog mod, pre-98 sails, dings removed, A4 side-markers, clear head-light corners, T-red chrome front & back. Aussie Bar waiting for installation.
"Monkey is my business...and business is good!"
Posts: 433 |
Originally posted by Rob98SVT2663: I'm in...sent email as requested but didn't see my "name" in your roster.
Thanx!
 I got it.
Silver Frost 2000 SVT #1443 of 2150 Mirror Tint/ Momo shift knob/ Kurtz Kustom pedals Ventshield raingaurds, moonroof and hood bug deflectors True Rev Induction Kit/ BAT Air Inlet Pipe Philips HID kit/ PIAA superwhite fogs/ Chrome Gas Bonnet Lifters Top of line Alpine system( NVE-N851A, DVA-5205, IVA-C800, TUE-T011A, KCE-150V, CHA-S624, PRA-H400), PPI (PC 4100, PC 2150,PRO 10's), Image Dynamics CD2 Comp MH and IDQ-62. Motorola Timeport HF car kit Looking to increase performance! http://photos.yahoo.com/hpick1 Future Mods waiting to be put on: Lotek Guage Pod w/ volt, a/f ratio, and oil pressue. Blue neon undercar kit Aussie Bar w/ upgraded backing plate Bullitt Fuel Door Magnacore Wires Ground Control Kit w/ Koni Struts
Posts: 433 |
Originally posted by tdavidk: Are these the ones that don't require any drill and tap? If so I am intested!  The guys with the Mondeo'd didn't have to drill and they said we shouldn't have to either...check out the other thread it has MadMoles install tips.
Posts: 2,066 |
Mad Mole's Mondeo: He installed them without drilling and he seems to think that we won't either, since he said that we have bolts in the same place. Heres his install notes below: Required Tools: 10mm open ended spanner Time Required: 20 mins Supplier: Performance Solutions , tel 01604 232003 Pop the Bonnet and tighten the bottom two alignment bolts on the hinges Remove the top two bolts on the hinges (that's why we tightened the bottom ones, so the setting cant change) Screw into these holes the two strut ends that have the threaded bolt (not the self taping end), tighten with the spanner. Dont forget to use a washer Undo the middle of the three wing retaining screws (level with the coolant reservoir) Screw the two self tapping end into these holes again using a washer (watch out for wires underneath) Screw the thin end of the gas strut into the top fitting Screw the bottom end of the gas strut into the bottom fitting (lift the bonnet higher to do this) making sure the top is held and doesn't unscrew Stand back and admire Does that help?
