#255129 04/03/02 03:52 AM
Hey Guys,
Well Ford had put some wonderful hardware on the rear suspension of my car. I need new struts and springs. Any suggestions as of what to get??? 1997 Ford Contour GL Zetec
#255130 04/03/02 03:58 AM
9
9
How many miles do you have on them? Decide how much money you can spend and then look at your options
99 Tropic green svt
Custom Stereo
borla cat-back
22mm bat rear sway bar
custom K&N & heatshield
215/40/ZR17 Rubber
jimmkreider@yahoo.com
#255131 04/04/02 11:55 AM
I only have 50k on them, which I thought was mediocre. Found some Monroe Sensa Trac's they are rumored to be decent. Koni's are about twice the price!!
#255132 04/04/02 04:05 PM
1
1
Hey, I used to have a 99 SE and when I had it, I put the BAT kit in - but now I have an SVT. I still have a set of original 99 SE springs and struts left - if you think that they will fit your 97 and you want them I will sell them to you. They do have 50K miles on them but they did not have any problems when I had them replaced with BAT kit at a local shop.
1999 T-Red SVT #45 of 2760
No Mods
#255133 04/04/02 05:32 PM
I will find out from ford if they will fit and i will let you know thanks!
#255134 04/04/02 11:56 PM
Y
Y
They will fit your car if you use BOTH the springs AND struts from the '99 . They changed styles of (front) springs from Gen.1 to Gen.2 Contours , so they changed the struts accordingly . One style had a "pigtail" type spring & one style had a "straight-cut" spring , that's the easiest I can describe it to you . The rear spring (and strut) styles are the same for Gen.1 and Gen.2 . Strut dampening is another topic (you'll do just fine with the '99 SE struts) .
~~~~~~~~~~~~~~~Allen
********** Love Those REDWINGS !!! **********
2000 Contour SVT Black w/ Tan #2137 of 2150 / built 2-4-00
Mods : ~ Factory DRL mod ~ "Powered by Ford" seatbelt covers
~ OF's TH fix ~ Audi A-6 Side Repeaters ~ Highs in Lows Mod
~ #885 foggies ~ KKM filter ~ Mondeo ST200 Badging & Shiftknob
~ Pre-98 Sails ~ Nose Bra ~ Trunk cargo net ~ '98 Clock
~ "Glasspacked" Resonator ~ Painted Rear Reflector
~ Räzo Pedals ~ Custom "Mondeo" Windscreen Banner ~ Ventvisors
~ Lighted Moonroof Switch ~ Mystique Rear Seat Light
~ Painted Grille Ring ~ H&R Springs & Mondeo ST200 Struts
~ Mille Miglia "Cello" Wheels
My old 95 \'Tour SE ~ New SVT pics here
#255135 04/05/02 05:51 PM
alright thanks! what do you want for the struts and springs (4) also do you know if the struts would work with eibach lowering springs?
#255136 04/05/02 08:33 PM
1
1
Ok, I just looked on ford part outlet website - new would be ~$446 plus shipping. How about $220? I have no idea whether it's high or low.
As for eibach springs - I don't know an answer to your question but I read somewhere on this site a while back that your struts need to match your springs. Personally, I loved my BAT kit and it just worked out in a way that I couldn't take it off my old tour before trading it in. But it was pricey - with labor it cost me $800+ (but again, it was a sweet ride)
No Mods
