Posts: 93 |
I have been looking for this one for a while, I just looked at my brakes today to see if upgrading to E0 calipers would be possible (after machining the rotors of course). I notice the cracks then. This is the second time, the first time the rotor were replaced under warrantee. So now I must ask, what causes rotors to crack? I understand that you must first overload the brakes before cracking can even occur, but...
Why do rotors crack?
Geoff C. Turner
99 Black SVT -mine 99 Blue SE V6 ATX -mom's 96 Black SE MTX -sister's
Posts: 955 |
well if your braking and your rotors heat up, and then suddenly hit a some water, that can cause them to crack, or bent. im going to replace mine because they are bent, but only once i have the money. need to get suspension, its on the virge of breaking.
Experience is the worst teacher; it gives the test before presenting the lesson. "You peel my onion down to the nun" - Gene Hackman [Under Suspicion] -Walter- 96 Contour LX
Posts: 2,375 |
As nitros was saying brakes crack when they exceed the heat capacity of the metal- if you want a technical explination read further if not kewl.
ill try and make it short- its about a 50 page segment in the book Engineer to Win by Carrol Smith, MBI Publishing Co. Osceola, WI 1984. You sdhould purchase this book if you have any of these sort of questions- Carrol was the race engineer to Shelby aMerican during most of his life and if considered a guenius (sp) in the industry- his books are very well written and can be understood by anyone.- they are all about $25 and the ones to read are: Engineer to Win Prepare to Win Nuts, Bolts and Fasteners Tune to Win
If you read these you will be VASTLY better at all things automotive.
You must first understand the properties of metals and the basic checmical compounds and behaviors of crystalin structures (thats the atomic structure that all metals have). Metals like to arraing themselves in to c=rystaline latices and form stable "blocks"- but when rotors are made they are made of cast iron - more specifically "Gray Iron"- (Quoting from the book) "Gray IRon is the most common tyoe of cast iron used in the foundry. Gray iron is basically a matrix of iron and silicon in a solid solution intersperced with pparticles of carbon in the form of very thin interconnected FLAKES of graphite. Because more carbon can be dissolved in molten iron than can be dissolved in to iron in a solid state, the graphite is precipitated out of solution with the iron during the cooling process. The mechanical properties of gry iron are affected be how much carbon is present (ie how much space within the lattice do the flakes use), the size and distribution of the flakes and by the hardness of the metallic matrix. Simply put, the higher the carbon and/or silicon content and the slower the cooling process, the more and larger will be the graphite flakes and softer and weaker will be the matrix. Like most materials in flake form (corn flakes for instance) the graphite flakes themselves are both weak and brittle and the volume that they occupy within the matrix has little mechanical strength. Thr presence of the flakes however does give gray iron its excellent castability and machinability so that complex parts may be cast and machined economically. The material has modest tensle strength values (up to about 55,000 psi, ultimte), good wear resitence, excellent internal vibration damping ability and thermal stability and a good resitance to galling." Engineer to Win: page 50
that is the makeup of your rotors. now why they crack:
Plastic and Elastic deformation of metals
(this is along and complex chapter so ill summerize)
When you place a metal under a tension or compression load you are trying to change its matrix shape. The matel by nature and its atomic bonds will deform a certain degree and still have the ability to "spring" back into its original shape- you all have done this with metal - bend it but then it goes back to normal. if you exceed the bonds ability to stay together the metal the goes from elastic to plastic deformation. This is when you stress the atomic matrix to such and extent that it will actually shift its self to accomodate the pressure. when you add heat to this process everything becomes easier to do- ie try to bend a cold bar as opposed to a white hot one- the hot one is easier. This is why if you are going to puchase metal - be sure you get the cold rolled type- it is much stronger and often not much more money. So back to heat distorion or plastic deformation. then your gray iron rotors are clamped by the calipers it is in a compressive type of stress- Gray iron is very good in that application of stress and that is why it used in brake rotors- but then these pads create friction and now the rotor is transormed into a giant heatsink. Iron is not as good as say aluminum at dispersing heat- it tends to retain much of the applied heat- so when it gets HOT the rotor now under extream heat and compressive force begins to exceed its capabilities at the atomic level and a shift in the matrix occures, manytimes this is felt as brake whobble. As often as the rotors warp they also get "baked" or exceed their heat abosorbtion capabilities- this is when crackes occure- they are called stress fractures. Caused by a combination of excess heat and stress they form along Grain boundries within the atomic structure of the metal- (these can be seen easily on a piece of galvinized sheet metal- all the different colored spots are grain boundries) these crackes are also prevelant along these flakes and also any casting and or machining flwas within the rotor. once your rotors havew begun to crack they are destined for the scrap heap- get rid of them as soon as you can afford to- and get a better uality rotor- and these arent always the nicest or most expensive rotors on the market- any brake rotor company worth your time should be able to tell you the exact metalic compund and structure and give you a data sheet (paper showing the batch resistance to fatigue heat sheer tensile ect) of your batch ect.
hope this helps- if not my wrists ache and ill answer any other questions later.
scot
Posts: 93 |
Thanks a lot, I have read some of the X-to-win series, but I haven't read all of them yet.
Horse, your post (which was very helpful thank you), only seems to explain where the rotors crack, not why, but I may guess it is differing rates of cooling.
I have never hit puddles after heavy braking, period. Also my rotors have never warped either.
So my current thinking is that rotors are intented to be a homogenous mixture of carbon silica, and iron. However as everone knowes truly homogenous mixtures are impossible. So the cracks are forming on the phase boundaries, and the different phase have different cooling rates, therefore causing the cracking.
Back to practicality, what to do about the rotors.
1. Upgrade my brake system, larger rotors can handle more heat 2. Upgrade my rotors, are there better quality rotors out there?
Geoff C. Turner
Posts: 12 |
From what i understand the water is only causing the crack because it rapidly changing the temp of the metal, another cause could just be running the brakes hard and not letting them gradually cool down. I would suggest that if you run on tracks or autocross you try to gradually lessen the heat on the rotors on the cool down lap or in the parking lot, the largest stress on the rotors occurs when you really them up and the park. Hope this helps..and there is always drilled rotors..im not sure what effect this has on a street car in terms of wear but in a high heat application it will only improve the life of your brake pad and rotors Scott
98.5 svt 18 rs-5, yoko parada, B&M short shift, 2 10in jl audio subs, Poineer??,ppi, poor man's kkm, no res, painted gilles and oval,NO TINT!?
Posts: 2,375 |
yes while upgrading your braking system will without a doubt improve your stopping distances and lessen fade- it also costs mega $$$ for less and also a huge improvement- you could by the best pads and the best rotors you can find- this will only cost you about say 400- versus about 1400
Posts: 3,934 |
Instead of trying to remember the benifits of freezing metal parts, I am going to give you a page. This would be a good route to go if you were looking for an improvement, but didn't have the cash for a complete system. Diversified Cryogenics The people I have talked to there are quite helpful. Non-slotted/non-drilled SVT front rotors were about $98/ea for Raybestos PG parts. And...Stock rotors, heated to the point where they actually glow, makes those nice stress cracks pretty quickly.  Yes, I let them cool, thats why they are only now minimally warped.
· Jon Miconi
· 96 Contour Zetec ATX · 80 Ramcharger 360 ATX · 77 Ramcharger 440 ATX
