I know that conventional wisdom states that when you get your rotors machined, that you should replace your brake pads.
I've wondered why this is?
My thinking is, wouldn't the softer compounds of the pads even out in just a couple uses when mated with the newly machined surface of the rotor?
The reason I'm questioning is that I have warped front rotors (mild) but I know the pads Mintex have tons of life left in them and it just seems like a waste to replace them.
