9
9
I purchased a used set (24K) of rear SVT rotors. The rotors are in very good condition and according to the seller are not warped. I want to lightly etch the surface of the rotors before I put them on. Should I just use some sandpaper?
I don't want to cut them...I did that with my stock rear rotors and they warped after that. Thanks.
'95 Ford Contour SE ATX...primarily the wife's car
'86 Ford Mustang LX notch 5.0 5-speed...12 second project
A light sanding is fine, if that's what you had in mind.
Moderated by  Andy W._dup1
